Best pots for audio ?
Thanks again chip_mk
I will do a search on the pots you recommend. But can you tell me why you prefer them - is it price or quality etc?
My PC is quite an ordinary device, operating under Linux (Debian) and I do not see any form of specialised audio facility. At this stage I am using VLC for both audio and video playback of lossless (MS Windows) recordings.
So perhaps straightforward analogue - therefore mech. pots - would be the best option to use here, taking the full, unattenuated output from the PC into the analogue preamplifier ?
Allen Bradley pots don't appear to be available in South Africa - unfortunately.
When I looked AB up in Google, they act as agents here for other international companies involved in industrial control such motor speed controls etc.
Will check out your other suggestions too, many thanks !
I believe Nobel makes high quality potentiometers.
Thank you, I have heard of them;
Unfortunately, there is no supplier here in South Africa of that brand - I will have to choose between Bourne & Vishay for pots.
But my concern is whether to go for cermet or conductive plstic
- or even wire-wound. So some experimenting is called for .....
Many thanks
Greetings all !!
Potentiometers have become hugely expensive, apart from the old carbon types. What would members recommend for typical audio pre-amplifiers (eg: volume & tone controls, etc) ?
I would be looking for low noise, long life types. Are wire-wound pots 'over-kill' ? thanks for any comments/advice
For volume controls, I am very fond of the Baxandall/Self/Puzeys active circuits.
When the load of the cursor has a high impedance, high quality pots are not needed.
High end microphone pre-amplifiers use:
24 Position Rotary Switches.
If you go this route, be aware of "make before break" versus "break before make" switch types.
I made a 30 positions stepped volume control using a rotary switch which was of the break before make sort. It does not act as a potentiometer but as an attenuator. The lower resistor (connected to ground) is of fixed value (around 300 Ohm) and there is only one resistor connected at a time in the upper section (bar a high value resistor around 1 MOhm from the input to the output). So there are only two resistors in the signal path. Electronically, it is probably the best circuit but the stepped interface is not as comfortable as a continuous good old rotary potentiometer having a nice attenuation law.
attachment.php
683973d1527670301-pots-audio-ctrlvol_att-30-pos-jpg
this type of attenuator can become very noisy in an area close to transmission towers. It is a real antenna!
