Current boosted unity-gain opamp
I am trying to make unity-gain power buffer which will be used with tube preamp. The schematics seems to be working, at least in simulator. Is everything OK? Will this circuit be stable?
Thank you.
A 8Mhz audio op-amp, even if it is unity gain stable, can't have enough phase margin with such a lag as the load (each transistor stage contributes >90 deg lag at some point at HF).
A simple solution for servos and the like is to add a capacitor across input terminals of op-amp (requires a series resistor at one end). Other frequency compensation solutions involve: taking split feedback before and after output stage, or compensating output stage in such a way that phase margin is 45 deg at the frequency where circuit runs out of open-loop gain.
Such circuits where op-amps and transistors are mixed shall be tested in breadboard for transient response at low and high temperature (heat gun or box/light bulb and IR thermometer), to ensure reliability.
There is also another problem. The OPamp power supply should always be more than half of the output stage power supply voltage, or the inputs of the OPamp can end up being driven outside their common mode range (i.e. too close to the OPamp power supply rails) which can have various detrimental effects depending on the OPamp used. Usually the OPamp OLG becomes non-linear and degrades close to at least one rail, and in some cases worse things such as phase reversal and latch-up can happen. With OPamps prone to that kind of behavior, feeding an input signal with a too high rise or fall time, or too high a frequency, or just driving the circuit to clipping, can cause overshoot and oscillation which will repeatedly drive the OPamp input stage into modes of operation it cannot stand, leading to serious problems and potential circuit destruction.
The OPamp power supply should always be more than half of the output stage power supply voltage, or the inputs of the OPamp can end up being driven outside their common mode.
Where this "more than half of the output stage power supply voltage" comes from ?
Not all op amps are the same, some are rail to rail some are latch up free, some don' t.
Obviously, for this design this should be considered.
I have changed opamp to LM4562 - 55 Mhz bandwidth and unity-gain stable.
Still I don´t know how to compensate the circuit.
The important point is improving the speed of the buffer, not the opamp. Having a 55 MHz GBW makes this problem worse than the 8 MHz of the original circuit, instead you need to focus on improving the speed of the output stage and figuring out how to let it peacefully cross the unity gain frequency.
What about this?
I have changed output transistors to mosfets, back to OPA134 and added opamp compensation. Is it worth building the prototype for testing?
