Nice clear work but i can't see the safety GND connection. 😕
This is absolutely necessary for your metal chassis.
Safety reasons!!!
Safety reasons!!!
Gurpreet Turna it,s not best drawing this power supply try again the capacitors are too small ...
Ok. Which one u suggest
Safety reasons!!!
my precious 🙂
DC 50-0-50,bias 45mA, offset 3.4mA
Thanks to Mr. Mile and the members of this forum
Very good case and buid Fuego
Which tone control you use for your AX-14
Not safe yet!
3mm screw isn't enouph for a safety GND connection.
Use Y cable and connect the second cable at the bottom
of the metal chassis using at least 4 mm stainless steel screw and grovers.
thank youNot safe yet!
2-pairs AX-14, stereo can be fitted on 196mm x 150mm heatsink 196MM width/150MM length extruded aluminum heat sink.
fan cooling for keeping things cool.
regards
Prasi
regards
Prasi
Excellent Mr. pcb!
I like this configuration with +/- wires close together.😉
Thanks Mr. DIY!😀
Hi friends,
Posting here a PCB layout for "APEX Stereo Protect" kindly see and suggest me something I am missing, so that I can improve, once verified I will post the PDFs.
Thanks and regards.
Anoop
Dear Anoop,
Please post the schematic used by the side of the PCB or in the same PDF file. This will help a lot of questions.
--Sarma.
regards
Prasi
Nice! master pcb..
regards
Prasi
Prasi perfect [emoji122][emoji122][emoji122]
- 100W Ultimate Fidelity Amplifier
