Hi Guys,
I just thought you might like to see this extravagant use of the latest SB Acoustics Be tweeters.
Ulfberht Be - TektonDesign LLC
Actually, given the number of tweeters, I have to say this guy is getting a MAJOR discount from SB. I have no idea how it sounds, but I can't really stop laughing. Thoughts?
Best,
E
Best,
E
That was my reaction, but i haven’t heard them and the people that like them really seem to like them.
dave
One of my design goals is to keep drivers within a quarter wavelength at the XO…
dave
The website is full of bizarre designs -- and rave reviews -- but I have not heard anything from this vendor. Generally if I saw a speaker with 15 tweeters at a show I would likely skip the room. But now I'm interested to hear people's impressions.
With DSP using tweeters like that for the midrange could be used to control beamwidth but the drivers look too far apart vertically to do likewise when crossing between the types of driver. But I haven't done the sums and may be wrong.
Of course it is most likely the usual audiophile nonsense but DSP is enabling one or two interesting new things.
Actually I like the hexagonal array of tweeters. I think it's a pretty clever solution to the coaxial vs. separate drivers. In past designs, this array was both tweeter, and mid.
I'm not sure how he's using them here. Are the hexagons now just mids? If so, I cannot imagine they'd be better than cones of similar diameter, just a lot more expensive.
Best,
E
Best,
E
Mmm. I see since launching this Be dome model the following priceless drivel has mysteriously vanished from the page of the cheaper silk-dome version:
Give me strength. 🙄 Give me strength.
Important Note: did you know sound waves travel through beryllium over 37 times faster than sound waves travel through air?! Talk about a mismatch and a serious conflict of musical interests! Sounds travel through pulps and textiles at or less than the speed of sound through air so air always wins the race over the transverse propagation of the vibrations through the cone. In my opinion, beryllium pistons are a giant no-no as the vibrating source of your sound.
For example: in a beryllium-based acoustic device, the vibrations travel through the beryllium transversely and internally from the voice coil source to the outer cone edge 37 times faster than the sound can radiate from the inner-center of the cone to the outer edge of the cone through the air. Anyone care to listen to a solid beryllium or magnesium violin? Highly doubtful.
Yeah- counterintuitive if you ask me. Also- there is no way a pair of Dayton RSS315 will net 99dB sensitivity, nor are they from pro-sound origins.
FAIL!
Wolf
FAIL!
Wolf
The man is crazy,have you guys seen his patent about woofer cones needing to be as light as the string of a bass guitar for natural reproduction? After 15years vi learned to stay farr away from these subjectivists...
Maybe he can also say which bass string ? 😉 Have you read the patent ? Is it at least entertaining ?
Charles
And for that matter, since the moving mass changes when you shorten the string by pressing it to the fret...
Yes, the patent is worth reading if you enjoy a good laugh.
Do those tweeters achieve constant directivity or are they just marketing gimmick??
From the Double Impact page:
Proprietary controlled directivity - acoustically superior proprietary polygon-oriented, triple-ring radiator high frequency array. This array disperses a precisely focused acoustical power pattern of that of a horn or waveguide without the audible ringing influence of horn flare walls constraining the soundwave for acoustically superior mid-range high frequency performance
That's all well and good, but do your designs "literally strike out at the listener with percussive elements and a constant velocity that matches all musical instruments and the human voice" ? 🙄One of my design goals is to keep drivers within a quarter wavelength at the XO…
dave
¡Ay, caramba!
-Gnobuddy
Yeah, but then what's with the one between the two arrays?
Of course he deserves to be ruthlessly mocked for his techno-poetry. But!
Pinheads mocking him on the internet SELLS.
Patents SELL.
Marketing drivel SELLS.
Speakers that are easy loads and play loudly SELL.
He's not unhappy with a dis-favorable rating from us tire kickers.
Patents SELL.
So long as people are daft enough to pay that sort of money for those speakers they will keep making them.
I am perfectly happy with my 1980 Fane 12-50WRMS in a W bin.
Paid £20 for the speaker second hand and whatever it cost to build the w bin out of plywood.
- Tekton is using up all the Beryllium!
