In LTSpice sims of amps, we often put 10,000uF as input cap to remove any effect of inadequate coupling - it shows the lowest distortion possible. But can you hear the difference?
I guess that is the million dollar question. Certainly the different cap brands sound different at the sizes I have tried (up to 1500uF). I believe Mark was asserting that at 10,000uF, the distortion will be so low that capacitor quality becomes irrelevant--all caps will sound alike. With a desktop amp and no size limitation, I think this strategy may be worth a try for a few bucks.
So no bypass cap needed on this 10,000uF electrolytic? Maybe 4700uF is almost as good and an easier size to get in a reasonable size. I have some 10,000uF 25v caps that measure closer to 7000 to 8000uF.
Not sure. TBH it seems too good to be true, but I'd like to find out more. Unfortunately Small Signal Audio Design is a $60 book. Just made a (much lower) offer on eBay. We'll see if I get lucky.
My MoFo amp has a single 4700uF 35v Panasonic FC cap as an output coupler. No bypass caps and it sounds quite wonderful. It can drive speakers at 8ohms or even 6ohms, it can drive *ANY* headphone as it has 12 watts on tap (28.6vpp into 8ohms). I listen to it and have measured it, really no lack of sparkle at all. Maybe some truth to big output caps not needing any bypass.
This is a follow up review of several of the DIY headphone amps presented in the past months through several brands of headphones.
My original post on the Salas DCG3 build is #2131, for the XRK971 build is #1229 and the Pass DIY build is #820 for anyone wanting to read my first thoughts.
Since that posting, I have purchased through a MassDrop buy, a set of Sennheiser HD6XX phones, which I believe are actually HD650 cans. New additions on the headphone amp side include one of Pete Millet's Korg Nutube headphone amps and a desktop (AC) version of XRK971 PCA. This amp is biased at 120ma, running larger Panasonic caps on the output and very large caps (15000uf) on the power input than a battery operated version of the PCA. The Nutube amp also has a pair of Burson V6i opamps in place of the recommended OPA551 opamps. The Pass DIY by Wayne has a Sparkoslab SS3602 in place of the AD823.
Play back is now through a SMSL M8A DAC with a clean outboard 5vdc supply. Also inline is an Uptone USB Regen. The audio file is a .FLAC. All systems are given a minimum of 24hrs at room temperature before listening.
Last time I used a live performance of Dave Brubeck's "Take Five". This time I am using a Pink Floyd song from their 1973 album "Dark Side of the Moon". That song is " The Great Gig in the Sky". The instruments are a piano, Hammond organ, pedal steel guitar, bass, and drums. The main vocals are supplied in an almost orgasmic way by Clare Torry. Her wailing reveals much about the amps and headphones!!
Salas DCG3
Sennheiser HD6XX
Wide soundstage with drums and Torry appear in the center. Cymbals are clear and crisp sounding. Organ far left, piano front in right ear. Vocals soar with no obvious distortion. The piano is well defined.
HiFi 400i
Similar wide stage as the Sennheiser cans, spoken voice clear. The cymbals and Torry's vocals are not as clear as with the Sennheiser phones. Bass is very defined. For the second set of vocals Torry is slightly overpowered by the piano. Piano and bass are clearly defined.
Thinkd Sound ON-2
Soundstage appears lower and more separated. Cymbals are clear and defined. Vocals are centered and also well defined. Drums and cymbals crisp sounding. There is a better balance with the piano and Torry. Piano crisp with nice overtones.
OB1
Nice base definition. Good soundstage, though drums and cymbals are masked somewhat by the organ and piano. Torry vocals are a bit muddy sounding. In her second set of vocals the sound is more subdued as well the piano is less defined. Overall a more muted sound not as defined, though not unpleasant to listen to.
Ultrasone Pro 750
Piano sounds slightly smeared with a bright sound. Drums and cymbals have very clear sizzle to their sound. Hammond organ very dominate in left ear. Torry's 2nd vocals are clean sounding the piano sound is rounded, with the bass somewhat subdued.
Sony 7506
Piano is thin sounding, with the bass rounded and full sounding. Drums and cymbals are prominent and defined. Torry's vocals are the most upfront sounding of the headphones I have. In her 2nd set of vocals the bass is very dominate with the piano still sounding thin, not as defined.
Audio Technica ATH-M50
A very detailed piano, with good bass, nice wide soundstage. The drums are distinct with the cymbals having a clear sizzle to their sound. Torry's vocals clearly defined. The Hammond organ has a nice mellow sound. Torry's 2nd vocals are still defined and the bass is very present. However she appears to sound more in the background with the bass and piano up front.
XKR971 desktop Pocket Headphone Amp
Ultrasone Pro 750
Piano smeared somewhat, not as distinct. Drums are clear and the cymbals have a nice sizzle sound to them. Hammond organ sounds muddy, not as clear. Torry's vocals are bright. In the 2nd part the piano is still a bit muddy sounding, though there is a nice balance with vocals, piano and bass.
Piano clean sounding with a wide soundstage. Hammond organ is distinct. Drums and bass are more pronounced. The vocals are not as clear and defined.
Sony 7506
Vocal very clear. Pedal steel and organ are clean and clear sounding. Drum and cymbals are well defined. The bass is very pronounced. In 2nd set Torry's vocals are a bit shrill sounding, but clear. Individual piano notes are clear. For this amp and song this headphones really are nice.
HiFi 400i
Wide soundstage with a clear organ and piano. Nice airy vocals with the drums and cymbals crisp. Hammond organ is distinct with a good balance on vocals and rest of the instruments. Torry's 2nd vocals really soar and the piano is nice and round with distinct overtones.
OB1
Wide soundstage with defined bass and clear pedal steel. A good blend of organ, drums, vocals and piano. Smooth clear 2nd vocals and piano. There is a nice balance with good depth in the soundstage.
Think Sound ON2
Slightly bright piano. The pedal steel sound smooth, with nice drums and cymbals sizzle. The organ is clean and defined. The bass is very solid along with clean, clear vocals. Torry's 2nd vocals and overall sound are nicely balanced. The piano and bass are balanced with the piano not as bright. Her vocals are very light and smooth.
Sennheiser HD6XX
Piano very natural sounding, with the pedal steel smooth and rounded. A wide soundstage with the drums somewhat muted and cymbals not as crisp sounding. The vocals are further in the background. Her 2nd vocals are distinct and soaring. The piano is very nice with the bass sounding further back, not as dominate. Overall a good balance.
Pete Millet Korg headphone amp.
HiFi 400i
Nice wide soundstage with a natural sounding piano. Clear pedal steel and crisp sounding drums and cymbals. The Hammond organ is nice and distinct, with Torry's vocals being more centered and clear. In the 2nd there is a good balance between the vocal, piano, and bass. Torry's voice seems to float above it all.
Good bass with a wide soundstage. Pedal steel is not as distinct. The drums are more forward, additionally the organ and drums seem to overpower the vocals a bit. Her second vocals are better sounding balance with the instruments. They also are brighter and pushed back in the soundstage. The bass is very prominent.
Sennheiser HD6XX
Another wide soundstage with the pedal steel and vocals clear. The Hammond organ is distinct. Drums have a nice balance with the crisp cymbals coming through. Overall good balance between the vocal and instruments. Torry's vocals just seem to float and soar in this 2nd bit, with the piano notes clear and distinct. The bass appears at a slightly lower level.
Sony 7506
Defined piano and bass on a wide soundstage. The pedal steel is distinct with the drums sounding upfront, though a bit over powering. Torry's vocals are clear and distinct as is the Hammond organ. In the second part she is heard a bit more forward in depth and every bit as clear. Piano and bass are well defined.
Think Sound ON2
Rounded bass and pedal steel with the piano not as defined. A nice wide soundstage. The Hammond organ and vocals are defined. The cymbal really has nice sizzle and the drums are very forward. Torry's vocals in the second part seem pushed back, but still distinct. The piano and bass dominate in this section.
OB-1
A wide soundstage, with a forward sounding piano. Pedal steel not as distinct, with the overall sound not as defined. The organ, drums, piano are blending together more. Vocal is also muddy sounding. Same for the 2nd bit, vocals sound muted, with the piano not as defined. However the balance of the piano, bass and vocals is ok.
Ultrasone Pro750
Another wide soundstage. Overall a bit light sounding, not in your face. The pedal steel and Hammond organ are clear and defined. Piano though sounds muddy. The cymbals sound almost a bit artificial sounding. Torry's vocals are clear. The bass and piano have a nice balance in this second bit with her vocals centered though a little muddy sounding.
Wayne's Pass Headphone Amp
Wide soundstage, with a clear pedal steel and full sounding bass. Upfront Hammond organ, with distinct drum and cymbal sounds. Vocals appear pushed back, but very distinct sounding. In the second bit, piano and vocals have a nice balance and still are clear and distinct. The bass seems a bit upfront.
Sony 7506
Piano and pedal steel are distinct and clear. Vocals are more forward and clear. Same with Hammond organ and piano. The bass is dominate. For the 2nd bit vocals are airy and distinct with a nice balance against the piano. Bass is at an even level, not too forward.
HiFi 400i
Piano, bass, and pedal steel are distinct on a nice wide soundstage, with a nice balance. The cymbals are a bit down and sound slightly muted. The vocals and Hammond organ not as clear. In the second, Torry's vocals seem a bit smeared sounding and not as bright. The piano and bass are nice sounding with good imaging. The vocals sound more forward.
Think Sound ON-2
Nice balance on the piano and pedal steel. The organ and Torry's vocals are distinct and a bit more forward. Drums and cymbals have a clear sound with nice sizzle. In the second bit, the bass, piano and vocals still maintain a nice balance, plus the vocal are still distinct. The bass is not as dominate. Overall a very smooth rounded sound.
OB-1
Piano, pedal steel and bass are nicely balanced on a wide soundstage. Cymbals are crisp and distinct. Vocals are not as clear, with the bass and Hammond organ dominate. For the 2nd bit the bass still dominates, the piano is distinct. The vocals have some smear but are more forwad in the soundstage.
Sennheiser HD6XX
Needs more drive from this headphone amp. Bass not so forward, with the pedal steel and piano nice and rounded. The drums and vocals seem a bit pushed back, with the cymbals sounding very natural. The organ is clear and distinct. Nice overtones in the second bit with Torry's vocals more prominent. Piano and bass have a nice balance.
Ultrasone Pro 750
A wide soundstage, with the cymbals lacking some sizzle. Organ and vocals sound slightly muddy. For the second part the piano and Torry's vocals are distinct. Both appear centered in the soundstage with the piano slightly more forward. The bass is nicely matched with the piano and vocals.
This posting is just one person's thoughts on how some of the DIY headphone amps and various headphones sound. Your listening results will certainly differ from mine.
For me it is a lot about the build and then the enjoyment of listening to something I have built. Thanks to the many out there that can design these amps and are willing to share with the rest of us.
David
Salas DCG3
Sennheiser HD6XX
HiFi 400i
Thinkd Sound ON-2
OB1
Ultrasone Pro 750
Sony 7506
Ultrasone Pro 750
Sony 7506
HiFi 400i
OB1
Think Sound ON2
Sennheiser HD6XX
HiFi 400i
Sennheiser HD6XX
Sony 7506
Think Sound ON2
OB-1
Ultrasone Pro750
Sony 7506
HiFi 400i
Think Sound ON-2
OB-1
Sennheiser HD6XX
Ultrasone Pro 750
David
DrPro,
Thanks so much for taking the time to compare and post your findings That's a lot of work, I know it is!
I do enjoy the PCA with the OB-1 - they seem a great match. Others have told me that the HD-650 was almost made for the PCA based on how well the matching was. I recently got a pair of HE400i's and trying with various amps. One thing is for sure, it likes an amp with a lot of grunt. Not surprisingly, the MoFo, driven by the Aksa Lender pre (so capable of 28.6Vpp) does a very admirable job with the HE400i.
DrPro, wow, that is a lot of data to absorb! The only headphones we both have is the M50, so I payed most attention to those entries. My best friend just got the closed Status Audio cans...I want to try pairing them with the PCA.
My biggest audio revelation of late has been my first taste of the NOS DAC sound. I'm like you: I tend to get absolutely obsessed with critical listening. With this thing, I am just relaxing into entire albums for the first time in so very long. It lacks the spacious separation and minute details of a Sabre chip, but it has the most natural, glare-free timbre, and the most 3-d soundstage, of any source I have owned. Great match with the Pocket Class A and AT M50. It also pairs wonderfully with my Fostex planars, which are so incisively detailed and tend to be fatiguing in the treble with my other sources. "Musical" is the word.
Stellar now you have piqued my interest in the NOS DAC. I am not at all familiar with it. I have scanned that thread by Matt. So what is needed to make a working DAC?
David
David
something slightly unrelated, but just wanted to update here.
I wanted to make an output cap bank, goals being relatively small size but customizable with required capacitance.
able to take stereo channels. I have this status ob-1 paired with ESP HPA. and x suggested this way to protect the phones.
I have ordered cap bank pcbs today and if anyone is interested they can also order here
output cap bank (2)- Share Project - PCBWay
or can have it from me , once I build and test it. I plan to use NP caps bypassed with film caps. 6 x 220u 25V and 4x 1u Film.
the board can take 10mm dia caps and 1 to 2u2 film caps.
The caps can be fitted both on top as well as bottom. electrolytic can also be fitted on bottom.
Soldering sequence is very important. Top row followed by bottom row and so on until you achieve required value.
One could also use normal electrolytics, but back to back for split supply. So its flexible.
here is the sch, top view and bottom flipped view.
regards
Prasi
To XRK,
I have the cap bank tested and works really well. I have 8x 220uF NP caps & 2 x 1uF film caps per channel for the Status OB-1 phones paired to ESP P113.
regards
Prasi
Cool looking setup there - I know nothing of non oversampling DACs. What’s the attraction to them and why do we have to make one from scratch?
The DAC on my Cayin N3 (AK4490EN) sounds very nice - I can’t complain about harshness in the treble, or much anything other than a mild pop when changing song sampling rates. I might look into an NOS if I can understand inherently why a NOS DAC would intrinsically sound better. I seem to remember that oversampling is great for error correction.
The convenience of portability and interface of the N3 is an unbeatable value at this price point.
Cayin N3 Review - Headfonics.com
Nice work Prasi. Do you have a photo?
What is a NP cap?
Thanks,
X
NP is Nonpolar or Bipolar electrolytic Cap.
regards
Prasi
Ok, nice. That looks like a Nazar shunt but missing output transistors?
yes the Nazar shunt, but converted to plain vanilla LM317-337, didnt have the D44XXX at the time.
I am also going to build the LM317/337 with keantoken KMX, to see if it makes any difference
I didn’t have the D44xxx either is picked closest TO220 BJTs.
Any updates on availability of the desktop PCA board or the pocket power reg board?
X, I know you are busy with your beastly ALPHA amps lately 🙂
Question for those that do testing. I have purchased a small Focusrite USB Solo and downloaded the REW software. I have been exploring this evening, using the RTA function. My goal is to adjust the second harmonic on my BA-3 pre. Along with further measurements later on. Really not sure what the proper setup is. I have admired X's screenshots of the various builds.
Any advice/pointers would be great.
David
David
- Group Buys
- xrk971 Pocket Class A Headamp GB
