I often find piano notes too sharp, is there a tool for flattening them? A file maybeThe piano notes sound sharper, the strings have more detail in their vibrations.
Bbe is a technology that puts back what the recording process takes out.
Apparently a recording cannot capture all the qualities of an actual live performance.
A piano will sound different when in the room being played for you than it will being played through a set of speakers. Bbe puts back the 'realness' of the instrument sound
Compares what a piano sounds like or a drum or strings or trumpet with what it sounds like from a recording.How does it know what was taken out?
Its partly tk do with the transients and the phase shifts. Anyway barcus berry electronics puts a brightness into a piano or a preciseness to a harp being plucked. It does it electronically but for some content it can appear a little too sharpn bright so 3 levels are available as well as off.
Just when you think you're getting through with your cutting remarks .......
How does it know what these instruments "sound like"?
This might interest you, particularly the last section, "The Records".Bbe is a technology that puts back what the recording process takes out.
http://www.jasmine-records.co.uk/other/downloads/jascd656.pdf
It takes in the input electronically.How does it know what these instruments "sound like"?
Skimmed it... too long winded. But thanks.This might interest you, particularly the last section, "The Records".
You have three levels to pick from 1 2 and 3. Some find 3 too harsh and indeed too sharp. A bit like having the contrast set too high on old televisions.I often find piano notes too sharp, is there a tool for flattening them? A file maybe
Others like it better with the bbe off altogether and still others throw a wet towel over the speakers in the hope of dulling the sound from instrument notes that are too sharp.
Each to their own..
You haven't read the last short section? It's an example of what can be done in the real world. I have this remastered version, and when you consider the circumstances of the original recording it's amazing
Bbe has xome from lots of test that compare what an instrument sounds like afainst what a recording played through speakers sounds like in comparison.If the source is a pig veils all the nuances etc , how can BBE retrieve those info? <snip>
The object is to make the latter sound like the former isnt it... well bbe does just that.
I am old enough to have owned a R2R deck. It wasn't a particular good one and I no longer have it, but my comments are not based on listening to others' anecdotes. I also still have a cassette deck (and vinyl, and CD - I even have DAT too).armarra1 said:I'm not a recording professional therefore i have little knowledge of R2R and from the sound of it neither do you apart from anecdotal.
Pure nonsense. Cat 5 is too thin for speakers. Thick wires do no harm.sumotan said:Btw Armarra 1 too thick a wire you loose more highs.
For really cheap & good speaker cables, I can recommend
that you try diy Belden Cat 5 cables
It isn't, so he can't tell you why it "is".armarra1 said:Thats interesting about the highs. Do you know why that is ?
Because I like music.cbdb said:Why would you want your system to sound like live music?
I can only assume you don't know what the term 'hi-fi' means.Most live music is not very hi fi.
You would need a Maxwell demon to do that. Maybe the demon some have already bought to reduce noise can do this new function too?armarra1 said:Emphasis of certain frequencies in a dynamic(automatic) way can bring out detail that was there but hidden.
Pure nonsense - unless you have a tame demon.Bbe is a technology that puts back what the recording process takes out.
Demons know.RAndyB said:How does it know what these instruments "sound like"?
Thats fine fir goodman but not feasable for multiple recordings. Bbe works on anythingYou haven't read the last short section? It's an example of what can be done in the real world. I have this remastered version, and when you consider the circumstances of the original recording it's amazing
Thats like saying which dolby SR do you refer to.Which BBE product are you describing?
It's a very simple question, should I have said products? Ok, which BBE products are you describing?
BBE is a feature of a product.It's a very simple question, should I have said products? Ok, which BBE products are you describing?
A tape player is a product.
It either has solby or it doesnt.
Bbe is a feature that some products (tape players etc) have.
Agreed.Because I like music.
I didn't want to say that out loud.I can only assume you don't know what the term 'hi-fi' means.
Ah! now we are getting somewhere! I'll try ebay first for a tame demon.Pure nonsense - unless you have a tame demon.
Demons know.
I can't find a sample stream anywhere on the 'net. 🙁 It would be fascinating to hear " the warmer sound of the original LPs without the clicks"This might interest you, particularly the last section, "The Records".
The first section about how jazz became " bourgeois" is interesting
- General Interest
- Everything Else
- Music Reproduction Systems - what are we trying to achieve?
