Hi
Can the AX14 amplifier be powered at +-70v?
Thank you
Yes but with 3 output pairs
uff...it was from alex mm , but don´t know exactly
it is OK, I will try to find out by pictures that you posted. nice work by the way!
Yes it's my PCB design ....uff...it was from alex mm , but don´t know exactly
one of the most complicated designs done into 1 side PCB, well done, admirable work
Hi Prasi,
Thanks for the Gerber files.
Rick
Hello Rick, Nicely done..
1 with 4700u63V and another with 2200u50V.
What is the End application?
All the best.
regards
Prasi
Agreed...Alex mm is simply one of the best, if not the best Sprint layout masters around here!
Great! COngratulations on successful build of fx-8. Do post if you observe any improvements with cap bank.Prasi,
1 is for V4H PeeCeeBee, the other is for FX-8 Bimo Mod & any other i might like to try it out on. BTW the FX-8 Bimo Mod is also from your Gerber files. Thanks again, the FX-8 is currently singing minus the Cap Bank.
Rick
Prasi
Hi Prasi,
Rick
Is that some old AR loudspeaker behind the desk?
Prasi,
It is singing sweetly. The cap bank does help with all the music i have tried. it seems to me to help most with orchestral music that swells up. Gives it more body if that makes sense to you.
Anyway, thanks again.
Rick
Thanks Rick for the update.
Prasi
And PCB.
NOT TESTED
Zener diode polarity is reverted...
And PCB.
NOT TESTED
How about trying to avoid as many straps as possible? Especially those carrying more current...
- 100W Ultimate Fidelity Amplifier
