But what about the price? LM4562NA two times cheaper than LME49720NA. If the same there is no reason to buy one that is more expensive
Through whom? And which package?
I get my stuff through Mouser mostly, and we're talking $3 for them both in SOIC and DIP. Think they're the same price looking up 49720 and 4562. I spend the big bucks on the 49860's though, (3.17 in singles and only SOIC) for that sweet wider voltage range.
LME49720NA/NOPB | Texas Instruments | TI Store
LM4562NA/NOPB | Texas Instruments | TI Store
Both probably getting more expensive???
XE: USD / MYR Currency Chart. US Dollar to Malaysian Ringgit Rates
hm... in my local store I guess original (not fake) DIP-8:
LM4562NA $3
LME49720NA $5.5
Looks like it is local shop issue of price 🙂
LM4562NA $3
LME49720NA $5.5
P.S. I'd be very interested in comparisons with the Yamaha R-S202 as well, since that can be had for ~$120)
- hello! IMO- it's not worth to worry! I have Yamaha A-S300, that costs apr. Eur 300 ... But that's sound make me cry ... 😡
Eur 75,00 TPA3255 plate from Audiophonics not comparable much- much better than...
Hi AleksandrsB,
The Audiophonics board looks nice but does it have a POP sound when turned ON/OFF?
Is it silent when no music is playing or does it have some kind of hum?
Hi AleksandrsB,
That's the same as the aliexpress ~40 € board (without 3.3V regulator, but blue board).
I bought it and it worked OK for a week, then it started producing popping sounds (for 30s, a couple of pops a second) when powering it up, during which no audio could be played. Then it works ok.. except that now it also sometimes produces pops after being powered and used for a while.
There is no hum or hiss (when it's working properly)! I am using Meanwell LRS-350-48 to power it.
Because of these problems I ordered tpa3251 board from 3e-audio...
Hello, my nordish neighbor finnsam
== That's the same as the aliexpress ~40 € board ==
Yes, you are right in main ... But- not exact, and You, I hope, know- Who going into hiding in details ... ;-) !?
That similar boards go to sell in ali approx. Eur 50 ... plus 21% TAX ... plus Custom/postal fee ... It is not so cheap, as can see for a first look...
This board NOT almost perfect, but that do not have haotic pop's on stand-by ;-)
Hello,
anybody here compared class A amp (tube or SS) and TPA3250 amp? Any impressions?
Thanks!
Thanks!
Huh... In my clos future program is Old School legendary JLH amp. launching (i'm already have a JLH- board) and direct comparing vs. TPA3255 and Irdamp 7 irs2092 to ...
Yes, I have both an F5 and the TPA3255 EV board.
The Class D is running with a linear supply at 53V and I changed the input capacitors.
F5 is built with quality parts and choke supply. Speakers are an easy load at 8 ohms and good SPL.
I was fighting against it, but I like the TPA more than the F5 right now.
F5 Pro-more HF-extension, slightly more natural in general maybe and maybe a little better in decay of notes.
TPA pro-everything else 😱 Much better bass control, midrange is clearer, stage is more structured and focused. When the F5 articulates very well, the Class D does even more of that. F5 appears to be a little blurred in comparison, which was surprising to me. Probably a result of the 150 W at 8 ohms.
And there is no listener fatigue, which I always encountered after a while with all class D or chip amps. It even swings and got the rhythm...and no harshness.
And it seems to be very revealing to the source, my 3 preamps never sounded that much different before.
For my ears I like it best with a good valve preamp, it seems to add a little pleasant distortion and some meat on the bones😛
If there is a weakness, then in HF extension and resolution, but this can well be the filter characteristics not matching with my 8 ohm speakers. Just not as fluid as I know it from other amps, a little damped, but hardly noticeable. Are there better amps? Of course! But not in my house right now.
But for the 80$ shipped this was a huge bargain; and my V-Fet amp is still waiting for its built.
Maybe this helps...
Maybe this helps...
Thanks! It helps.. 🙂 next project in sight.. never had a Class D amp, except at my bass combo, TC Electronic brand, but I did not like the sound of that specific combo.
Hello,
Thanks!
Wonderful question!
Also has anyone compared good-implementation of Class AB (eg. TDA7294/TDA7265) to Class D TPA325x platform?
AleksandrsB, my quick guess Jogi is referring to FirstWatts Nelson Pass/Audio Express F5 Class A JFet amplifer
Thanks Forestsgump, yes, Pass F5; I thought everybody would know 😀
Of course my "review" is only valid in my environment, but it may give some kind of compass. Maybe with very efficient speakers (+96db) it will be different, but I am sure that the TPA will not be a disappointment, when there is no crappy source or speaker involved.
- Class D
- TPA3250 somebody is listening?
