Yes read a book about Eimac tubes
https://frank.pocnet.net/other/Eimac/Eimac_1969_Quick-Ref.pdf
http://w5jgv.com/downloads/Eimac-1975.PDF
Thanks to Soundhappy for posting these links and stuff. My eye was caught with this PP tube headphone amp: MJ1801_(04)5670WA-pp-headphone-amp_YanagisawaM.pdf - Google Drive
What do you tube experts say - would it be worth the effort to build? Any design flaws?
I'm afraid that the Noguchi output transformer PMF-8P-10K is not available in europe. What would be a suitable replacement?
lots here:
(try google translate)
schematics, layouts, etc.
Tube links
Index of /inf/Amplifier
Valves' World ?????
Projekty lampowe
http://fonar.com.pl/a_index.htm
https://robrobinette.com/How_Amps_Work.htm
http://www.preservationsound.com/wp-content/uploads/
http://www.4tubes.com/SCHEMATICS/BY-BRAND/Antique-Sound-Lab/antique/Power_AMP_HG.htm
http://www2u.biglobe.ne.jp/~hu_amp/
Tube links
Valves' World ?????
Projekty lampowe
The current source used has, in my experience at least, very uneven impedance depending on frequency. One can bridge rectify the 6V winding, ground the positive side of that supply, then you end up with a negative rail which allows for a higher performance CCS.Thanks to Soundhappy for posting these links and stuff. My eye was caught with this PP tube headphone amp: MJ1801_(04)5670WA-pp-headphone-amp_YanagisawaM.pdf - Google Drive
Power is so low that the choice of output transformer is quite open.
News about older articles now available.
That is possible only because work of Distant Past Radio Boy
Thanks for all DIY spirit of knowledge share with generosity
Update today 12 | march | 2018
I see a 15E amplifier! Always wanted to try this little tube. Any link to index or info on "Distant Past Radio Boy"? Google provided me with nothing.
-Kent
-Kent
@ Kent
Yes vacuum tube DIY hobby amateur :
See " About Us " link on this page :
Google Traduction
Best regards
Could you elaborate on this? What CCS would you use that requires a negative rail?
schematics
Many thanks for your continued postings!!!
How does one access schematics?
- Tubes / Valves
- Gold mine of DI¥ audio tubes schematics from Japan
