supa phono preamplifier pcb
you can bypass T18/20 and R16/20 and C9/10 (called gyrotor in the original article), they are used for noise reducction on the power supply, or simply bypass only the ps regulator (IC1/2, C11/12 and C13/14) and check the result for noise. Depends how good your own +/- 18 V PS is, regarding noise.
BR
Günni.
I'd like to read the original article.
Can someone give me a link to it?
Appreciated
Thank you scafas for your work, pcb has arrived. Instead of 2 x 10nF, I used one EMZ KS57 20 nF (polystyrene). If you plan next versions, you can think about converting pcb into some MKP 470 nF with 15 - 17.5 mm pitch. Thanks again. Regards
I have a technics sl-23 with a audio technica at95e on it. Will this work well with it? Do you still have boards? Do you sell kits with the components or would I have to get them as well? What power does it take?
Thank you for your time.
the Sln work well on yuor turntable , accept +15,0,-15 vdc and you can buy the bare board on my ebay .
if want a complete kit send me a PM.
DIY pcb phono Super Low Noise ELEKTOR preamplifier | eBay
