Threshold S/1000 optical bias??
But this is DIYAudio! I gotta give it a try.
I think I'll probably send them in. Swapping components I can do, I'm not even sure where to find meter parts, how to calibrate, etc. But for now the amp sounds the same even with it's stubby little needle frantically swing back and forth at the top of the meter.
I did swapping the large Mallory cans, Spectrol one turn biastrimmer for a multiturn Bourns, electrolytic on the frontend and a faulty powertransistor bulbs and meterperpex with real glass. That was not really DIY like cloning an amp but better than nothing...
Those meters is a specialist job I reckon. You can't just glue on the missing part it seems to me.
http://www.diyaudio.com/forums/attachment.php?attachmentid=664312&stc=1&d=1519408856
Perhaps you will appreciate these 1985 brochure pages, which
is all I have on the amplifier.
Yes I know I have them too but how about a Threshold S/1000 optical bias as depicted in my first post?
I'm almost sure that there wasn't a optical bias version of the Threshold S/1000 only of the SA/1, that is to say with the Thresholds that had VU meters.
Do you concur with that or did Threshold make S/1000 optical bias upgrades with a complete new frontplate (probably as expensive as the 1000VA Fischer & Holden toroid it had) as well?
Thanks for the highres scans though
Did your FET 10 have the same layout on the PC board? I've found a few pictures on-line of the FET 10 board, but none are even close to mine.
Thanks,
Eric
No probably not. I just looks like an Threshold pre-amp from that era.
It has probably more in common with the FET 10e or 11.
The pre-amps that were sold in the era of the Threshold S/1000 Series II were the FET One and Two Series II designed by Eric Lauchli
