Polystyrene capacitors for RIAA circuit
Hi everyone,
I built a very nice tube phono stage and I want to try polystyrene capacitors in RIAA correction circuit. As of now I found at farnell capacitors from LCR brand, values required 200pF and 8200pF. Can anyone recommend another source for polystyrene capacitors? I checked ebay for Siemen KS NOS, but couldn't find the values. I also read good things about Reliable Capacitors.
Axial polystyrene capacitors are not good for RIAA- too much parasitic inductance .Siemens KS are extended foil, radial low inductance type.
Here's a 10nF 50V XICON (axial) on the VNA.
Let me see if I understand your "problem".
These capacitors are ruler flat behaving like perfect textbook examples between 100Hz and 10MEGA Hertz, with a resonance at 15MHz , probably due to lead inductance since it seems to apply equally to all capacitance values, ... and you are agonizing about its response at AUDIO frequencies?
Gimme a break !!!!!!
