Very Odd ... Just reboot and look if build is resuming ... at this stage, there is only some rm and cp commands (and one db update) ... no huge risk to destroy your build 😉
Finally I restarted from the beginning, after several reboots due to some errors I'm finally enjoying the new 4.0 version... What a great job !
Great Thanks to the team!
Tested that on beta version ... so yes, it is possible via command line (Tim will confirm but i think you couldn't do that via UI) 😉
Is this via enabling MPD output 1 and 5 at same time or is it a more complicated config?
It does not have to be in Pi when you set the background. It will allow you to browse a picture on your PC then upload to Pi. Very convenient.
OK, thx. It didn't work here, but I forgot to put the Alpha blend factor to 0.
Now it works like a charm...
Thx!
Hello everyone,
I installed MoodeAudio v4 release. everything is going well.
Except, some weird slowdown. But, my main question is this:
Is it possible to send music to my Wifi speakers? I thought yes, but impossible to do it. If yes, do you know how?
thank you in advance
Boxfirm
Boxfirm
Yes ... during initial setting and first testing phasis ... pretty sure that you told me to do mpc enable only 5 to avoid this 😉
Ram voltage
Hi
I have made som adjustments in the config.txt, and the sounds really improves 🙂
I have added these lines:
# Overclocking options
force_turbo=1
avoid_pwm_pll=1
arm_freq=466
over_voltage=-7
over_voltage_sdram_p=8
over_voltage_sdram_i=-4
over_voltage_sdram_c=-15
Is there anyone else that have tried som similar mods?
Cheers
Hi
force_turbo=1
avoid_pwm_pll=1
arm_freq=466
over_voltage=-7
Cheers
Dunno if this is the right place to ask for help but I certainly need some.
I am trying to have moodeaudio 4 started on my raspberry pi zero w but I seem unable to.
I tried in 2 ways: burning the ready made 4.0 image on an sd card and burning a Debian stretch image and then building mode on it via the 2.3 building script.
In both cases the same happens: the system starts, machine stays active for a short while like 2 minutes during which I can access it via ssh as normal, then the ssh connection is abruptly dropped and I can't do anything else thaN pulling the plug and restart.
Any ideas on what am I doing wrong?
Thanks in advance
Alberto
Thanks in advance
Alberto
Hi
The new Version 4 Installation worked well, until I tried to change the Themes Settings, which wasn't possible ( no themes-list,black window )
After clicking refresh, the GUI went white with a little background shining through.
Thanks in advance for tips...
Thanks in advance
Alberto
I think this was working for you, let me explain :
System start and then building is starting ... after step 1 complete, system reboot so you lost ssh ... but after reboot building continue to step 2 and so on.
You can monitor building process once log into PI with SSH via :
mosbrief ... Process continue until you see END via mosbrief 😉
(You will have around 8 reboots to complete the build and maybe something like 2 hours for RPI0W)
Sample after log via SSH :
Code:
Send automatic password
Linux kernel 4.9.59-v7+ running on armv7l architecture
____ __
__ _ ___ / __ \___/ /__
/ ' \/ _ \/ /_/ / _ / -_)
/_/_/_/\___/\____/\_,_/\__/
moOde audio player
(C) 2014 Tim Curtis
The programs included with Moode are free software; the
exact distribution terms for each program are described
in the individual files in /usr/share/doc/*/copyright.
Moode comes with absolutely no warranties expressed or
implied, or any other guarantees.
Last login: Wed Jan 31 21:33:36 2018 from xxx.xxx.xxx.xxx
pi@moode:~ $ mosbrief
// STEP 2 - Direct build so no need to expand Root partition
// STEP 3A - Install core packages
// STEP 3B - Install core packages
// STEP 4 - Install enhanced networking
** Compile bluez-alsa
// STEP 5 - Install Rotary encoder driver
** Compile WiringPi
** Compile rotary encoder driver
// STEP 6 - Compile and install MPD
// STEP 7 - Create moOde runtime environment
// STEP 8 - Install moOde sources and configs
// STEP 9 - Alsaequal
** STEP 10 - Squashfs option not selected
// STEP 11 - Optionally, install latest Linux Kernel
pi@moode:~ $
In this sample, building is currently at STEP 11 ... but not yet finished (You can have more details with moslast or moslog command)
You can also see that building is working via ACT LED on your RPI ... just after boot, led will blink a few, once building is starting or resuming ... led is always on until next reboot ... and this is like this for each step until the end where led will be back to normal use ( sometimes blink a few )
-Eric
I have tried to add jpeg several times from this screen but to date no luck. MoOde 4 allows me to select an image from my desktop and I can see the file was selected. As soon I enter update the jpeg is removed. Is there another step I have missed.
There's a size limitation on the upload as very large images would make things slow. The alpha value determines how much of the theme background to overlay on top of the image, this will let you use background images that might make the text hard to read. The fastest ui is going to be no background image with alpha set to 1.0 but the hit with background image and alpha isn't too bad.OK, thx. It didn't work here, but I forgot to put the Alpha blend factor to 0.
I usually have my Pi3 underclocked a bit which I thought sounded better, but haven't done it while development is ongoing. Read more here if interested: Archimago's Musings: MEASUREMENTS: Raspberry Pi 3 as USB Audio Streamer (with recommended CRAAP config & TIDAL/MQA arrives)I have made som adjustments in the config.txt, and the sounds really improves 🙂
force_turbo=1
I would first try clearing your browser cache and reloading, then if that doesn't work reboot your Pi, if neither helped then it's a more interesting problem that might require hitting the command line.Hi
Thanks to all of the Team for this lovely piece of software. I startet from the ground up, and I am not a linux enthusiast, but I managed it finally to run MoOde 4 final. It is great. Thanks Tim and the Team. I just made a Donation.
Best wishes from Germany
Does anyone use the scrollbars on the Pi Touch?
-Tim
I have tried them, but I find them very hard to use. I usually just scroll the list with my finger. That seems to work better for me.
Cheers, Bryce.
Thanks for the nice compliment and for your financial support for the moOde project!
-Tim
If it won't upload it may be too big...resize it to a file under 500kB.
Reduce the alpha blend from 1 to .35
After applying then reload the MoOde page in your browser.
Thanks to all - the ppl who helped with the auto script - to Tim for the new update and adapting the fuzz (FOSS) 🙂
I managed to build the beta with the recipe... (even thou I had no idea of what I did) - took like 3+ hours or so.
Today - auto script -> 1½ hour including the new sd card image.
Donation send.
Just wished the Spotify connect feature would be implemented so it could pause mpd/moode - as you can with airplay - and resume mpd/moode when airplay stops... really neat feature!
Still using the raspotify as before - it have implemented the librespot-org fork. It works, just need to pause moode before pushing play in spotify
And could someone teach me how to add images to manual radio links - have a few local radio stations. Cant seem to find a how-to in this thread.
Donation send.
Cheers, Bryce.
Hi Bryce,
What I'm finding is that momentum scrolling does not seem to work on the Pi Touch, maybe due to bug in the particular version of Chrome thats used, so I've left the scrollbars visible.
The default ugly white ones can be changed into nice overlay scrollbars via the chrome://flags setting thats described in the Build Recipe COMPONENT 8, 4c but that requires a kbd.
Another option is to simply disable the scrollbars altogether which can be done in CSS. This would eliminate the need for the messy config in 4c.
I'm just trying to get a read on the need for scrollbars.
-Tim
.....but I managed it finally to run MoOde 4 final.....
Is MoOde 4 Final out? I wanted to reattempt install until it moved from beta to final. Has that happened?
- PC Based
- Moode Audio Player for Raspberry Pi
