@MartinC700:
... I reckon you may want to program this yourself but just in case you are not aware of it the member dimdim has programmed a setup for the ES9028 &9038:
TFT HiFiDuino Pro Project | Dimdim's Blog
The youtube video two-thirds down the page shows what this software can do.
Jesper
Thanks Jesper, I am planning to use Dimitris' setup later, it does require some modification for the BIIISEPRO as it is written for the BIII with a sidecar. Once I get a little more adept at C++ I will try to adapt it.
You don't really need to worry about modifying my code for the B3SEPro. The code that deals with the sidecar can just be ignored - it doesn't do any harm.
But in any case, even though it's not necessary, knowledge of the Arduino IDE is good to have.
Thank you!
As long as you always have a master clock (of sufficient frequency) present (even if it is not in sync with your spdif source) your SPDIF will play just fine. Don't even sweat it. The important thing is just that there is a very clean *close* noise free master clock. 🙂
Also I would try running with the 100Mhz clock - even if your reclock externally - try it. Really... I mean it - objectively give it a spin. ES9028/38 are a new animal.
I have been switching between sync and async many times - and compared to the ES9018 - where I do think sync was a bit better - well I can't detect a difference at all on the 9038 - and I am very picky. I am quite certain there is no measurable difference.
Concentrate on simple clean wiring - let the DAC do the rest. 🙂
Cheers!
Russ
Thanks Russ, it will really simplify my implementation. The issue, I think, is that the McDualXO will not output anything given that the SPDIF signal will be bypassing the McFIFO (only DSD from RPi will be passing through the McFIFO). I'll clarify with Ian if the McDualXO can be used as the masterclock for the 9028 when the McFIFO isn't receiving a signal.
Paul
Paul
In any case what we know will work - is running async. Try it - you'll like it - and you will save yourself a lot of headache 🙂 It's going to be next to impossible to provide a lower noise clock than the one right next to the chip - well because of physics and proximity. 🙂
I am planning to upgrade my BII dac. I have connected this dac directly to a Hypex Ncore through a IVY III with 4vrms. I use the Placid HD v1.0 and Placid HD BP v1.0 to drive the dac. I use exau2i as i2s source.
I want to replace the dac with buffalo IIIse Pro with the new Mercury I/V but do not know if i should choose the ES9028 or the ES9038. Any suggestions?
Should I upgrade the power supplies? I understand that for the ES9038 an LCDPS is recommended. (HO kit or normal?)
9038 is not available from TPA yet. I guess you can also use Mercury with the BII.
It has been available for over a month now...
I ordered the ES9038 with a LCDPS HO and a Mercury. I plan to continue using the old Placid HD BP v1.0 for the Mercury.
IIRC you just need ~200 per side for the Mercury. 100mA + 100mA headroom.
This thread... # 16
www.diyaudio.com/forums/twisted-pea...-achieving-escape-velocity-2.html#post5234631
That's a fine choice - and should work nicely. 🙂
Cheers!
Russ
My BIIISE-Pro (9038) has been working for a little over a week now and is settling in nicely. Really a big jump over the 9018 version. Bass and overall resolution are terrific and the filters actually do something (not my experience with the older ESS dacs but they may be my aging ears).
I am using DIYINHK regs at present because I had them in hand and they work well though are overall much bulkier and so wiring in tidily is a challenge. My only issue has been running out of current on the 1.2v pins when running DSD which causes a sporadic wave of noise when running DSD128 or higher. I have moved to a different (LT1764) reg which definitely helps. I will go for a set of Trident SRs in due course simply to simplify and make more compact.
I find the Mercury i/v stage a big improvement over previous Legato (never had the IVY).
Great job guys, so thanks for all the late nights that undoubtedly went into designing and delivering this project. Now - did someone mention dual mono firmware? 🙂
Improvement with the ES9038 alone as drop-in replacement for ES9018 or the whole ES9018/Legato vs ES9038/Mercury?
Complete replacement -no half measures. I don't think you'll really get the best out of the new dacs without going all in.
Good strategy - that I’m not following because I love the Legatos. 😛. Mine are tweaked by ear to gain clear improvements versus the stock components. So I look forward to more good years of enjoyment before moving on... @barrows had tweaked Legatos and went to Mercury, IIRC. His direct impressions would be interesting!
Frank
Frank
So you'll go for the ES9028? Please report when it's done 🙂
Yep - 3 new 9028s. It will be a while b/c it’s a whole new installation in a new house, requiring new custom woofer cabinets and revised I2C DAC control code.So you'll go for the ES9028? Please report when it's done 🙂
- More Vendors...
- Twisted Pear
- Introducing the Buffalo III-SE-Pro 9028/9038
