I just built my very first speaker with the little knowledge I gathered from YouTube and research on different sites, but I'm still having trouble answering a few questions in regards to what power amp to use, and how the crossover's I purchased affect wattage and impedance.
I built mostly based on design, and that I just wanted to give it a try, so if my design and or choices for hardware are way off, that's why (and also why I'm writing this, so I can learn for next time).
Consists of .....
2 2-way speakers (w/3" Peerless PLS 75F25AL04 [8 ohm] and 4" Dayton Audio PC105-8 [8 ohm])
Peerless
8 ohm, 15wRMS/30wMAX, 100Hz-20kHz
Dayton Audio
8 ohm, 40wRMS/80wMAX, 80Hz-15kHz
Crossovers are DROK 2-way
150W, 4-8 ohms, 12db/oct on high and low frequency, 3200 Hz split
Amazon.com: DROK 150W Bass Treble Dual Channel Audio Frequency Divider Distributer, 4-8 Ohm 2-Way Crossover Filter for Subwoofer Hifi Speaker: Car Electronics
Amp is DROK 2 channel 50W digital amplifier
Amazon.com: DROK 50W+50W Dual Channel Stereo Amplifier, DC 9-24V 12V Mini Bluetooth 4.0 Audio Amplifier Car Home, HIFI Audio Receiver Amp Ampli Module with US-type Power Supply Adapter, Built-in EMI Filter: Home Audio & Theater
Here are my questions .....
Power - How is wattage calculated going through a crossover? Are the speakers split between the two channels going through the crossover? (meaning is the 15W and 40W added up = 55W then split in two to roughly 27W?) Or is the power I need the total 55W at what impedance? Also, what does the 150W rating on my crossover mean?
Impedance - How does the crossover affect impedance? I have two 8 ohm speakers, so does that make the impedance going through the crossover go down to 4, and therefore 4 ohm load needed from my amp?
I know, you're thinking this info is easily found on the internet, but for some reason every search I entered did not answer these questions. A little help is greatly appreciated!!! Thanks in advance from a new DIY Audio member.
-sdbarnold
Consists of .....
Peerless
Dayton Audio
-sdbarnold
Wattage (power) is usually measured with a sine wave test signal, at one single frequency. The amount of power delivered to the speakers is determined by the amplifier and speaker. An ideal crossover has no losses, and will have no effect on power delivered to the speaker - as long as the sine wave is within the frequency range that the crossover lets through itself.Power - How is wattage calculated going through a crossover?
Real crossovers have some small amount of power loss, because of the resistance of the inductor. So they will slightly lower the amount of power delivered to the speaker.
Things are different if you are talking about music, rather than a sine test tone. If music is played through the speaker, then the crossover divides up some frequencies to send to the woofer, and some to send to the tweeter. If you measure average power, usually most of the power ends up going to the woofer, and very little to the tweeter. But there may be very short bursts of higher power levels to the tweeter.
Since most of the power goes to the woofer, you can think of the system as still having only 40W of power handling capability.
I should add that the "40 W" number may be optimistic - some manufacturers inflate their power ratings to make the advertisement look more tempting. I have seen "25 W" speakers that would burn up or fall apart if you fed them even 10 watts.
15W and 40W are not the actual power delivered to the speaker - they are only a manufacturers specification for the maximum amount of power that speaker can handle without damage.Are the speakers split between the two channels going through the crossover? (meaning is the 15W and 40W added up = 55W then split in two to roughly 27W?)
The actual amount of power delivered depends on the amplifier (how many volts is it putting out?), and speaker impedance. That may be only 0.1 watt, or it may be 1 watt, or it may be 10 watts, or anything in between.
An analogy: if your car has a 15 gallon gas tank, that doesn't mean you have 15 gallons of gas in it. You may only have 5!
Forget all about that 55W, it is confusing the heck out of you.Or is the power I need the total 55W at what impedance?
The power you need is whatever is enough to play music at the loudness you want.
The speaker power handling needs to be able to cope with this. Hopefully, you are satisfied with the volume level before you get to 40 watts.
A small amount of power is wasted in the resistance of the coils in the crossover network. This power heats up the coils, and also creates a magnetic field in the iron core (you can see the core in the Amazon.com photos you linked to.)Also, what does the 150W rating on my crossover mean?
The 150W rating of the crossover means that the coil will survive the amount of heat, and magnetic field, that will be created if you pump 150 watts of music through that crossover, from amplifier to speaker.
First, I'm going to give you the super-simplified version: the crossover has no effect on impedance. If you have two 8 ohm speakers, your combined (crossover + woofer + tweeter) is still an 8 ohm system.Impedance - How does the crossover affect impedance? I have two 8 ohm speakers, so does that make the impedance going through the crossover go down to 4, and therefore 4 ohm load needed from my amp?
In reality, the question you asked is a big can of worms to open. The crossover network you bought from Amazon will work perfectly if loudspeakers were resistors, but they are not. Real speakers have big peaks and dips in their own impedance at different frequencies, and this "confuses" the crossover network, which ends up presenting even bigger peaks and dips in impedance to the amplifier. Real tweeters and woofers also have very different characteristics from each other (dispersion at the crossover frequency, sensitivity, time response), and a good crossover network has to take all that into account.
Real crossover networks in good loudspeaker systems are far more complex than the ones you can buy from Amazon or Parts Express. Designing them is part engineering, and part art. It is a very complicated thing to do correctly, and needs a lot of knowledge, a lot of expensive equipment, and an even more expensive anechoic chamber in which to do the measurements. Because of this, the vast majority of DIY loudspeakers don't get crossovers right.
But the wonderful thing about loudspeakers is that, however bad the crossover, enclosure, or drivers, some sort of sound will come out of them. This is enough to make many DIY speaker builders happy! 🙂
-Gnobuddy
Gnobuddy! Thanks so much for the detailed response. I'm still at work so just glanced at this, but man, I'll have some reading to do tonight. Really appreciate the help.
-sdbanold
-sdbanold
I just saw that the "50 W" amplifier comes with a 12 volt power supply. And you are using 8 ohm speakers.
That means the maximum power this amplifier can supply (before distorting) is about 5 watts RMS per channel. (Not fifty, but only five watts.)
I hope you are okay with that, and were not actually expecting 50 watts. Tthis is a very common problem, Amazon and other similar vendors are full of amplifier ads that promise five or ten times as much power as they actually deliver.
I have a similar amp and small speakers I use for my wife's computer. It runs on the same 12V, and the speakers are the same 8 ohms, so it also delivers about 5 watts RMS per channel. It's plenty for computer speakers, but it will not shake the plaster off your ceiling, if that's what you were hoping for. 🙁
-Gnobuddy
-Gnobuddy
Power: No splitting, max allowable power to your loudspeaker is 40 Wrms (same as the "woofer").
150 W is the maximum amplifier power which can be connected to the crossover, IF the woofer can handle 150 W.
Impedance: total impedance of your 2-way loudspeaker is 8 ohm (same as the "woofer") and that is the load to the amp.
Important point: your amp max power with 12 Vdc supply is 15 W at 8-ohm load if bridged, or 4 W if SE.
Use a 24 Vdc supply for about 35 W amp output power at 8-ohms, if bridged.
Edit: I didn't see that Gnobuddy already posted a very detailed answer.
Oh man, I didn't even think about that. So if I want more wattage, up the power supply to the amp, check. Thanks again fellas!
-sdbarnold
-sdbarnold
BTW *Sonce and *Gnobuddy, how are you coming up with your calculations for the voltage of my power supply, and the wattage it supplies to the speakers?? I'm doing some searching online and a couple calculators I found are not coming up with the numbers you guys did. -sdbarnold
Please.
Stop saying 'wattage'.
It's 'Power'.
Watt (or Watts - Plural) is the unit of measure.
Same goes for 'amperage'.
Amperes (or Amps) is the unit of measurement.
Another measurement of Power.
Ohms law will help you understand.
To me those butchered words are like someone asking how much milkerage can be squeezed out of a cow.
And increasing the voltage and current to the amplifier will most likely do no more than destroy it.
More for you to research.
The logarithmic relationship between power and DeciBells.
It's 'Power'.
Here is a link to a blog posting which may help you understanding how the crossover and driver impedance interacts:
A Speaker Maker's Journey: Crossover Basics - Impedance
There are simulation files available, so if you want to play with a completed design, you can do so here:
The LM-1 DIY Speaker is Available
Think of this as a free experimenting and learning lab. 🙂
Best,
E
Best,
E
Power from an amp is measured with a sine-wave signal. If we know the biggest (sine) voltage the amp can put out, we can calculate the power....how are you coming up with your calculations for the voltage of my power supply, and the wattage it supplies to the speakers?
(You might already know that the strength of a sine wave can be expressed in three different ways: peak value, peak-to-peak value, and RMS value.)
The type of amp you have is most likely four amplifiers packaged in one IC. Two of them are used for the left channel, two more for the right channel. Each pair in one channel are wired in what is called bridge mode.
In bridge mode, the *peak* voltage an amplifier can deliver to the speaker is equal to the power supply voltage, less any losses in the output transistors. A reasonable estimate is that there will be 1.5 volts of loss at the positive peak, and another 1.5 volts at the negative peak; so 3 volts altogether.
Okay, so with a 12V supply, and bridge-mode amplifier, it can deliver up to 9 volts peak (that's 12V - 3V).
The proper way to describe the power of an amplifier is the RMS power.
If you have 9 volts peak, and apply that to an 8 ohm speaker, the *peak* power is 9 x 9 /8, or just over 10 watts. The RMS power is exactly half of that, or about 5 watts RMS. This is the number I quoted in my previous post.
It is possible that the amp you have does not in fact operate in bridge mode. If that is the case, then the peak-to-peak (not peak) maximum output voltage will be about 9 volts.
That means the peak voltage is now only 4.5 volts. Half the voltage translates to one quarter of the power. That is about 1.25 watts RMS, instead of the 5 watts you'd get in bridge mode.
The two of us did not come up with the same numbers, either. People often forget to allow for the voltage losses in the output devices; if you plug 12V into the formula (instead of 9 V), you will get a wrong answer, a huge overestimate. In this case, you get the (wrong) answer of 9 watts RMS in bridge mode, 2.25 watts if not in bridge mode.a couple calculators I found are not coming up with the numbers you guys did.
If you post links to the calculators you tried, I may be able to figure out what they are doing wrong.
By the way, it's true that the mathematics predicts that more power supply voltage will get you more power - but we don't know if the electronics in that amp can actually handle more voltage, or whether it will just burn up instead. Did you get any kind of manufacturer data sheet (that lists allowable supply voltages) with the amp?
-Gnobuddy
This is not what you wanted to hear, but I really like the ridiculousness of "milkerage". I might have to start using it! 😀To me those butchered words are like someone asking how much milkerage can be squeezed out of a cow.
-Gnobuddy
Current (ampere, I) is not ("another measurement of") power.
Power is produced when a certain current flows in presence of a voltage (volt, U) difference (over a resistance, R). Power is calculated by multiplying the current with the voltage: P=I*U.
As U=I*R => P=U*U/R
For AC (a tone), if U is peak, RMS = U/1,4. (RMS is not "exactly half"...)
P=(12/1,4*12/1,4)/8=9,2 watt RMS.
And yes - it's the voltage and current on the speaker terminals that creates output power, not the power supply. Indeed one can get higher voltage on speaker terminals than what the supply (e.g. a battery) provides but never more power (but if you do - Nobel Prize for U!)
That means the peak voltage is now only 4.5 volts. Half the voltage translates to one quarter of the power. That is about 1.25 watts RMS, instead of the 5 watts you'd get in bridge mode....
This became a bit confusing...
Peak and p-p.... for a real word voltage, be it from a half bridge or a bridge, there is only peak-to-peak, p-p. Nothing is just "peak". Bridge gives you double the voltage swing compared to half-bridge (this is amplifier configuration technology). So in one case you have 9 V p-p and the other, 4,5 V p-p.
p-p/1,4 => RMS.
Hi sdbarnold, what kind of enclosures did you put these units into? I was contemplating on simulating your current speaker setup with premade amazon crossovers, and then maybe try suggesting mods to improve on it, if possible. The trouble is I can't possibly know the inductor value, only suspect it to be around 1.5 mH.
That Dayton Audio PC105-8 isn't a tweeter !
Why is it supposed to be crossed at > 1 kHz ?
Leave it for future projects...hmmm nice midrange ! Or it could be used as a mid woofer
for something smaller.
Try a cheapish cone tweeter if you don't like dome tweeters.
I disagree. All three measurements (peak to peak, peak, and RMS) have their uses, and all can be converted back and forth as needed.Peak and p-p.... for a real word voltage, be it from a half bridge or a bridge, there is only peak-to-peak, p-p. Nothing is just "peak".
Peak-to-peak is easiest to read off an oscilloscope screen.
Peak value is used to determine, for example, the necessary current rating for the output transistors, or when setting recording levels in your DAW.
RMS is the best description of actual power delivered to a load, particularly when the load is not purely resistive, but also has a reactive component.
Agreed!Bridge gives you double the voltage swing compared to half-bridge (this is amplifier configuration technology).
You are off by a factor of two - in one case you have 9 V peak to peak, in the other case, 18 volts peak to peak.So in one case you have 9 V p-p and the other, 4,5 V p-p.
This happens because, in bridge mode, each half of the bridge swings by 4.5 volts peak, in opposite directions, so the total peak voltage is 9 volts. The total peak-to-peak voltage is double that, or 18 volts.
Power can be calculated using either peak or peak to peak voltage (both will give the same answer if the proper formula is used):
P(RMS) = Vp*Vp/(2 R)
P(RMS) = Vpp*Vpp/(8 R)
And the answer is, about 5 watts RMS power into an 8 ohm load if in bridge mode; about 1.25 watts RMS power into 8 ohms if NOT in bridge mode.
These very low power levels are one of the reasons why automotive speakers are almost always 4 ohms rather than 8 ohms (doubles the power for the same 12V supply). It's also the reason many automotive amps are spec'd at a somewhat unrealistic 14.4 volts supply voltage, rather than at 12V.
That doubled power from using 4 ohms speakers still wasn't enough for many people, so car audio amps also sometimes use switching power supplies to raise the supply voltage internally, and/or bridge mode power amps to quadruple the output power for a given supply voltage and speaker impedance.
There are a few weird Bose car audio systems that use very low speaker impedances (around 1 or 2 ohms) in order to deliver more power with the same 12V supply rail, but that is an oddball that, thankfully, was not followed by anyone else in the automotive audio industry.
-Gnobuddy
and the Peerless PLS 75F25AL04 isn't a tweeter either !
What shall we do ?
As my speaker-designer former co-worker used to say, "They all make a sound. That's all that most people care about." 🙂What shall we do ?
-Gnobuddy
This is worth clarifying. Yes, RMS voltage is peak voltage divided by 1.4142... (the square root of two). So RMS voltage works out to be about 71% of the peak voltage, for a sine wave.For AC (a tone), if U is peak, RMS = U/1,4. (RMS is not "exactly half"...)
But RMS power is in fact exactly half of peak power (again, for a sine wave). This is because, if you square the square root of two, you get...two!
-Gnobuddy
- BEGINNER!! Need help understanding Crossover/Impedance/Wattage
