I'm still fighting the problem. Thank you very much for the answers. If I can not get out of it for a while, I will feel sorry for my affection.
Greetings.
Greetings.
Hey guys for support better ask directly to kipeta at his facebook page: Daphile - Inicio | Facebook
It finally happened. Greetings to all
What happened? You found your disk yourself or with assistance from Kipeta?
Hi everybody. An update about my suspend/shutdown problem on my Dell Z90D07:
With a fresh install on the internal drive of the last beta version using the "BIOS" option (not "UEFI"), shutdown works flawlessly... very good! 🙂
Unfortunately resume after suspend doesn't work, I get a blinking yellow led and no possibility to access Daphile again. I have to unplug the power to get the pc working again.
Ay suggestion about how to create a "persistent" log of suspend/resume events?
Thanks!
Thanks!
I don't believe Daphile has a resume option, but ask Kimmo on the website or Facebook page.
I would like to know what is the CPU that can upscale PCM to DSD512, i7700k is ok? I have the Holo Spring DAC and it should support on DSD 512.
I would like to know what is the CPU configuration that can support upscaling to DSD512? i7700k is ok?
I have a Holo Spring DAC and it should support on DSD512
I think i7 is enough.
Any configuration that I need to aware?
Make sure you use the latest beta. Also try playing from ram for a comparison. Also switch off the daphile audio device setting 'use only this DSD rate'. This forces daphile to upsample DSD recordings which is a lot more demanding on CPU.
I have a i5 4670k, 8GB RAM and SMSL M8a. Upsampling everything to DSD512 works OK for flac with the CPU load for 1m not exceeding 3 (ie. 75% load). Native DSD256 files play but stutter during complex passages. It sounds a lot better than Foobar DSD512 upsampling. I get the same result with an i3 8100. My g4560 does DSD256 but not DSD512.
Any setting in BIOS that I need to do if I want to upscale to DSD512, HY or etc? I am using ASUS z270.
Nothing of great significance. Disable the internal codec if you are not using it plus any other devices not required. Daphile provides a selection of power management options. I have played with these and not really noticed any differences. I use a mobo mounted 128gb m.2 drive for system (can go back to windows if ever required) and a single stick of 8gb ram. What case, PSU, storage and dac are you using? Do you intend adding a cd rom?
I am using Holo Spring DAC with SU1, and all my WAV files are stored in a SSD SATA drive. Also I use HDPLEX H5 silent case for my PC.
I would suggest you just get it running and then explore changes when you are ready. I would recommend a m.2 sSD for the daphile system drive as it reduces data cables and injection of noise.
- PC Based
- Daphile - Audiophile Music Server & Player OS
