SMD jfet test jig
Yes possible;)
Hopefully this is all the configurations out there as Gate on side with drain and source interchangeable I think it will cover all possible 3 pin jfets out there .:xmastree:
Jcarr, there is no need for any tape. The area on PCB has copper pours that will reliably do the same job. If you look carefully they are not just SOT 23 pads , but copper pours about 6 times wider than standard SOT23 pin width. Hopes that is what you are looking for with tapes.
