JLH 10 Watt class A amplifier
Hi Huggygood,
It has been a long time since i read this thread.
There are alot of potential improvements to be made to this amp.
It looks like Prasi has made a nice board design.
The settings have not been an issue for me in the 1996 version.
I am quite pleased with the sound from the 1996 version, to be fair I am using MJ15003, LM338K(T-03) upgraded supply a and some other small tweaks.
It is an old William Hart Audio PCB set.
Regarding the 2003 update, are you talking about Geoff Moss' work?
Do you have a link to the circuit?
- Dan
I see you have a 30w Hiraga as well. Did you compared them?
Thanks. If you always come back to jlh it has to be good 🙂 . Why all your amps are based on 69 schematic? Do you find it best sounding? I have to decide which version I'll build and I'm double-minded now 😀 .
Yes. They are both nice sounding amps,
I would not say better or worse, but they both sound good in different ways.
I will say that both of these amps have a good "imaging" ability.
But both consume alot of power and you need to invest in the power supply and heatsinks....
- Dan
Hi Huggygood,
- Dan
Yes. He talks about jlh 2003 version. I'll go with '69 anyway because I don't need more brightness and more bass would be useful 🙂 .
I'll try Chinese kit or this pcb
http://www.diyaudio.com/forums/solid-state/273226-opinion-pcb.html#post4298577 Alex mm made that pcb for me 2 years ago. I think it looks nice and compact what do you thing? I know that probably PSU caps are too small but that's not a big problem. I can always make PSU outside mentioned board 🙂 .
Hi Huggygood,
- Dan
no,hi have a big respect for Geoff Moss and his works.
a former forum member had taken over his work, made some changes, created a new pcb and marketed it as JLH 2005.
there is a theard on the forum that talks about it under the name "FREE pcb JLH 2005"
