Trying to replace my Carver Power amp
Hey guys, My Carver TFM-35 power amp is dead and I was thinking of building a chipamp instead.
I've been reading a lot about the LM3886 and TFM7294 (I think..) but I am still puzzled about some issues since there are many designs/kits around the chips, some with opamps some with coupling caps and some without.
My current main system is as follows:
Carver C-19 Vacuum Tube Reference Preamplifier
Carver TFM-35 Power Amplifier (DEAD)
Quart 350S Two Way Spk 4Ohms
I know that the rated Wattage of the TFM-35 is way higher than the Chipamps but I never played it that loud anyway.
Since I'm not too familiar in Audio electronics I have a few questions:
1. Since I use my current preamp, is it better to go with a basic Chipamp design or one with Opamps?
2. For the LM3886 Gaincard design is specified as latest/best, is that so? and is it true that it does not use coupling capcitors? and... if so is it better than with coupling caps?
3. I would like to use my dead Carver amp's PSU and heatsinks etc. Its AC voltages are 40/73/130 VAC so which design best matches those?
4. I'm probably miising other important issues so please feel free to inlight me :):)
Thanks for your help!!!
Joined 2013
#1 - I use a pre-amp with a LM3886 amp and works fine, so I think you will be fine (with or w/o pre)
#2 - I just built a MyRef verC - boards are available on eBay. 2pcs DIY LM3886T LM3886TF diyAudio My Reference rev.C Power Amplifier PCB Board | eBay Was sceptical, but with a 2x22Vac toroid it is a very capable amplifier.
#3 - you could use the heatsink (mine is 7"Wx2-1/2"Hx2"fins with a 1/4" base and it doesn't even get warm) for a stereo pair of LM3886 boards.
The PSU - too much voltage for a chip amp - max is generally 25Vac for 8-ohm speakers.
I think you have the basics covered - just have to make a decision on the amplifier (which is always the hardest part).
00940 Thanks for the info!
Bullitstang-
Thank you too for the useful data. Looked at the board, this one does not use Opas and speaker protection circuit, right? Does the Opa plays a major role?
(My understanding is that experimenting with different Opas can help improve the sound to one's liking)
As for the dead Carver,looks like only the case and heat-sinks are usable.
What continent are you on? Good transformer or switcher power supply vendors depend on that. In US Antekinc.com sells import power transformers with good reputation; in HGK connexelectronic.com sells switcher supplies which are more modern but require RF noise control.
As far as coupler caps in, I can't hear them & my hearing goes to 14 khz. I have a ST120 with caps in and out, a CS800s without, at same 1.5 W volume, on the same speakers, I can't hear the difference on the good channel. (one channel has low slew rate, slighty detectable). OPA op amps is another quibble I haven't dived into. I use FM radio a lot at a signal source, various LP's new & used, and very few LP's are in good enough condition or recorded well enough to stress my ST33078 op amps. I attend live performances and am an experienced musician, so I know what real instruments sound like. it took me 50 years in the hobby to afford speakers that even come close to live sound. The difference between .001% destortion & .0005% in the amp, PAH. Speakers cover all that up. 1% distortion is quite audible.
Serious heat sinks and maybe a fan are useful things to have, plus an enclosure. Hang on to the carver. Circuit breaker plus switch are handy, too.
What kind of music do you listen to? I listen at an average 1.5 W, but I like classical music, so on the cannon shot in 1812 overture, I like a 200 W peak. LM3886 won't quite do that. Rock pop EDM acoustic guitar have less dynamic range, so 1.5 - 10 w may be entirely pleasant. Acoustic piano needs 70 W anyway over 1.5 W average.
Two honey badger kit might fit in the Carver hulk, see link to diyaudiostore up in the top bar. This thread has various amp board recommendations where PCB are available www.diyaudio.com/forums/solid-state/314330-class-ab-amp-recommendations.html
Else there are various chip amp kits, atikita is one. I have suspicions of slew rate on LM3886 into 4 ohms particularly. 4 ohms takes more current. I hear slight fuzziness in bells, cymbals, top octave piano, on my AX6 board built with slow driver transistors.
Note to newbies, an output cap like the single supply atikita kit, can prevent you from burning up speakers if one solder joint pops loose and the output whangs to a supply rail. With split supply IMHO you need a speaker protection board like the $5 one being discussed in its own thread on solid state.
Have fun shopping & building.
PRR
Joined 2003
....The PSU - too much voltage for a chip amp - max is generally 25Vac for 8-ohm speakers......
Disagree, maybe.
I never understood Carver's "Magnetic Field" designs. Apparently some had a "regulator" ahead of the power transformer.
But looking at the manual cited by 00940, this *appears* to be a conventional supply, albeit with three +/- rails 25V 56V 98V for a 3-level class "G" amplifier.
The +/-25V rails (which power the most-of-the-time part of the 350 Watts, to maybe 50 Watts) have two 6800uFd caps, ample (and upgradable).
If he takes just the +/-25V taps to an amp, that's maybe 28 Watts in 8 Ohms or 50 Watts in 4 Ohms. That can be a lot of good music.
It is "stupid" to have a 700+ Watt transformer sitting around to give only 100 Watts. But it isn't doing much else, isn't heavy enough to anchor a rowboat, and is already IN the house (not shipped from Canada or China).
The question is: can he find the indicated points, tap them, and not get shocked or burn down the house. Minor point: can heatsinks cut for individual transistors accept the wide chip-amp package.
Carver is way too complicated to learn diy repair on. I've looked at the schematic, and didn't buy one. I bought a dead peavey instead, which is a lot simpler. 127 parts later, I should have done the high voltage buffer after op amp trick and gone straight to predrivers, drivers, and new output transistors. op-amp based, high-gain, high rail voltage, preamp See post # 7
I could build this circuit with wire on mcmelectronics dip project board. I didn't really need the Peavey VI limiter or the flying ground which allows channel bridging. Just a serious mosfet speaker disconnect on excessive current, instead of the triac crowbar that melted the traces off the board instead of blowing the breaker.
Disagree, maybe.
You're perfectly right, I didn't realize that the voltages on the transformers were in fact 65-36-20-0-20-36-65.
The easiest, looking at pictures of the beast, would probably to rip out all of the pcb (we don't know where the fault is), keep only the transformer, big 10.000u caps and the heatsinks, bolt a diode bridge to the bottom, a pair lm3886DR on the heatsinks and hardwire all that.
Maybe get a small kit from ebay for the VU meters but that isn't trivial if one wants more than just decoration.
edit: a small caveat though. The pics and schematics are for the tfm35x. I don't know if it is much different.
Well, thank you all for your feedback!
For starter, Indianjo- I'm from Israel. Love to hear various music types such Jazz, Rock, Soul & Classic among others.
PRR, thanks for the observation. I was looking at a printed schematics I have (see below) and took note of the ACV on the transformer which are wrong as they refer to the voltage between the transformer outputs. And BTW although it's called "Magnetic field..." the TFM isn't one. (lucky for me)
Looking at the pictures from 00940 ,the TFM 35 is different than the 35X, I have attached a photo of mine. So I think voltages don't match either. I need to check.
As for ripping off the Carver... I guess I cant go there mentally. I was thinking of maybe trying to repair it sometime as I have done before, but since its complicated design that includes feedback from one circuit to the other, failing to use the exact original transistors results in a kind of a domino collapse... which is what happen last time...resulting in a series of transistors and other components that gave up.
So that's how I got here. Thinking of building a Chipamp till I have the energy (and parts) for the Carver. After all I really love that beast.
Who knows, maybe I'll end up liking the Chipamp better?!!!
Ohh and about that...I spent so much time reading of different types of circuit designs etc till I got myself totally confused! Should I go for simple classic design or check things like My_Ref Fremen Edition ?
PRR
Joined 2003
I think this part is all the same. The schematic snip cuts-off the two 5000-10000uFd caps for the +/-25VDC rails, but they gotta be there. It appears the 0VAC wire changed from yellow to blue. Connector numbers look un-changed? And those large flat heatsinks are begging for big devices.
As for the amplifier details: I would not over-fret. Everybody has a favorite and praises it lavishly; but any horse may win on any given day. Throw darts at known good plans and just build one.
Administrator
Joined 2004
Hi Dedy,
For sure, repair the Carver. It's a really nice amplifier that can be made to sound better. This is a really nice amplifier and sometimes it is well worth having an expert repair something. Maybe once you have more money to allow for this.
I owned the Canadian warranty service shop for Carver and found them to be very reliable normally. Done right, you will appreciate an expert's work on this amplifier.
So, what happened when the amplifier failed, and what have you done in the past with it? The circuit boards are critical, so no matter what do not damage the PCB. There are some new parts that work fine in these amplifiers. So it is anything but a lost cause!
-Chris
