Another very fast CFA concept
Miro..thank you for the super amplifier,sound is beautiful.Many details, deep bass and beautiful heights.No.1
Something even faster - measurements
Sorry but I have to argue that yours is slightly slower than the very fast cfa consept.
In test pictures shown, the 400khz square of very fast is similar to your mosfet 300khz square wave response.
No I have never seen it, however I don't like the schematic, the input pair isn't included in the nfb loob, this means the input common collector input is runing without feedback lots of distortion.
I wanted to comment a bit more on why I don't like the schematic, I revisited the schematic once more, I found out that the input is a common emitter gain stage with current source bias, q11 and q12 acts as each others active load greatly increasing gain, however this collector output of q12 q11 has been shorted to ground by 169ohms this means it goes from a very large gain into a very small gain stage, the input is a cascode, the collectors connect to q3 q4 emiter like a telescopic cascode stage but slightly diffrent. it then drives another cascode gain stage then drives the outputs. The feedback sems to have a dc servo and it goes back to the emiter of q3 q4, at this point q11 q12 collector is also connected, collector cannot act as a feedback point and feeding signals into a collector of a transistor dosen't amplify, the input is running as a zero NFB config. I am supprised that simulation gives very low distriotion.
Hi Miro,
I send you some data 😀
Check your mail.
measurements from kct (Kay) and really good listening tests (my and from platon.rado) conviced me to try some improvements ...
today I did first shot with CCS
https://ctrlv.cz/shots/2017/11/17/Obus.png
These symmetric CCS I did:
https://ctrlv.cz/shots/2017/11/17/tEAT.png
https://ctrlv.cz/shots/2017/11/17/CQCq.png
Here is THD:
https://ctrlv.cz/shots/2017/11/17/pgEc.png
AC analysis:
https://ctrlv.cz/shots/2017/11/17/GddL.png
and current drift under working CCS:
https://ctrlv.cz/shots/2017/11/17/W21M.png
https://ctrlv.cz/shots/2017/11/17/g6G3.png
... CCS should be corrected for better values ... but this is only simulation ... if somebody have suggestions from experience? we can match them together ...
You have to put more effort to understand this amp. Input contains so called supper pairs (Boxall supper pair, sometime wrongly called Baxandall supper pair), it looks similar to the diamond buffer here. The 169R resistor (R19) is a part of NFB together with 470R (R12), and no cascode in the input, just in its output and in the output buffer.
This preamp use about 45 dB of GNFB and open loop gain (about 55 dB) is defined by ratio (R48/R19)*(R5/R15). I hope it will help you.
Don't be surprised with very low distortion.
Schematic in post #62 in my opinion use same strange resistor values and very low OPS question current. Attached my simulation. There is quite high crossover distortion and very low input impedance.
Damir
Just by decreasing values for R14 and R16 from 680k (very strange high value) to 47k shows much better results, but still very low input impedance not suitable for some preamps.
By the way, parallel capacitor(C14) to feedback resistor is not recommended in CFA.
Damir
Damir
Damir, as always good and helpfull work.
Thank you also for this usefull information.
Could you please, share the simulation file?
Thank you.
