Push Pull Amp, 4 x 6V6, 4 x 6SN7 and 2 83.
Output Transformer STANCOR NOS. <snip>
woww that looks cool!!
where did you get these mA panel meters?
Chsis
2x 8 watts
Single ended parallel EL 84 / 6P14P
Toroids with gaps?
Ferrite saturates in lower field strength than iron. You would need too much copper for low frequency transformer.
SRPP wit ecc 82
Built this pre for a year ago and I am very satisfied with the sound. In the amp today I have a pair of yugoslavian ecc82, just for testing, sounds perhaps a little bit "thin", but I will swap to a pair of Sylvania 5814A who sounds great.
Joined 2009
Super Muito
no heat build up inside...
You have to lid ( very easy to remove ) off the amp before listen to music.
Here's some of my stuff'
Left- Regulated Power Supply
Middle- 6SN7 or 6FQ7 (wired in extra sockets)w/ Reg PS- PreAmp
Right- SE 6AQ5
Not pictured are a PP 6V6 & 6BX7 SE (plug & play with the Regulated Power Supply)
MDF chassis, top edges routered, sides are about 1/2" space on side bottoms-for air flow, with 1/8" holes drilled on top, finished in truck bed coating. I built these in the late 90's. They still sound nice.
Right- SE 6AQ5
- Tubes / Valves
- Photo Gallery
