I bought the soft start board from the diy audio store. The bill of materials has this relay:
G5LA-14-CF-DC24 Omron Electronics | Mouser
Mouser reports this relay out of stock and no longer manufactured.
Could I change a component or two on the soft-start board to provide 12 volts to the relay coil instead of 24, allowing me to use this relay instead:
G5LE-14-DC12 Omron Electronics | Mouser
I want to keep the same pin and package while still using the diyaudio soft start board.
Also, these diodes are no longer available:
1N4007 ON Semiconductor / Fairchild | Mouser
Would these make a good substitute:
1N4007-E3/54 Vishay Semiconductors | Mouser
Thanks!
Thanks!
G5LA-14 24VDC G5LA-14 DC24 POWER RELAY 5A 24VDC 5 Pins x 10pcs
The relays are also available here, but with a $50 minimum order.
https://www.onlinecomponents.com/om...2cd6f86-3769-472b-818a-5c9da3ba7d98csPwwuEJ7p
Any 1N400X diode, from any mfr, will work.
