Some ideas,
a German site The Small ECL86 Amp, von Stefan Gloeden
and a Dutch site Single Ended PCL86 versterker. - forum.zelfbouwaudio.nl
Mona
Mona
6GW8 SE amp
Hi mate. If you are talking about the SE 6GW8 amplifier I built many years ago it worked flawlessly. No special requirements needed. Just be careful when you build the power supply regulator and the constant current sources. I have also made this with a 6BM8 tube. Not a problem. Also check your output transformer orientation. They should be at 90 degrees rotated from the power transformer and at a distance if possible.
Billy D...
hi...i have been following some of your psosts and and very impressed with your know how on great many thing with tube amps...
Billy D...
hi power supply for SE ECL86 amp
Hello Billy
Thanks for your reply!
could you please send me a schematic for power supply for Single ended ECL86 amp. maybe the schematic with layout of the whole amp.? would be thankful if you could!
i dont have have a choke. only the resistors and capacitors are available .
BR
Amit
Hello Billy
BR
Amit
Circuits
I have attached two power supplies and the main amplifier circuit diagrams. The power supplies do not need chokes as they are regulated and hum free. See how you go if you can build the power supply like these. Voltage requirements is up to you and can be adjusted by the zener string. The BUZ45 can be any fet that has at least 400 to 500 volt rating. A BUZ91 is more available and is to220 size and easier to work with. Must be mounted on heatsink! Then you would readjust the bias on the output tube to suit.
BillyD...
BillyD...
Thank you Billy!
i will look into what all i have to build this.!! i get B+270/ 280vdc after rectification with bridge rectifier. what mods do i need to make in the main amp circuit to suit this voltage??
Any tips on the layout?
BR
Amit
BR
Amit
Some ideas,
Mona
Thanks at least one of the circuit looks very simple!
is there some way to know if my tube is good or bad.? i know for sure that none of the pins are shorting from the heater to anything else and actually all the tubes i have are NOS and unused.
PCL86 Piccolo Triode Amplifier
the "Piccolo" PCL86 Amplifier
Integrated 2w/4w single-ended triode or ultralinear amplifier
Good luck!
What is the minimum voltage required for this schematic? I have a 220 to 110 volt trafo. After diode rectification,I will get 160 VDC. can I power it with this voltage. I am new to tube electronics and I am just building a pl504 low voltage amplifier. I have given orders for a 5K/ 8 OHM SE OPT. ( In my country,getting a ready-made SE opt is virtually impossible. I have to interact with a transformer winder and have him specifications and air gap details
to be made)I will be getting those next week, I intend to use this circuit with the 110 volt trafo I have.
Any modifications required? I am okay with a reduction in volume. Eventually I am planning to get a DC DC step up booster board and can use it for the rated B+
Thanks in advance
What is the minimum voltage required for this schematic? I have a 220 to 110 volt trafo. After diode rectification,I will get 160 VDC. can I power it with this voltage...
You will need to build a voltage doubler circuit off your 220:110 transformer and bring the B+ up to around 300v. A doubler is a simple circuit so its not a big problem.
- Tubes / Valves
- ECL86/PCL86 Schematic
