Inspired by this
The Eminence 20Hz Tapped Horn – Volvotreter Homepage
I wonder how difficult it would be to modify this design to use an 18" driver and a cutoff of 16Hz?
There will be much to learn over the weekend, and will be using modelling with software like Hornresp etc.
I am going to build a standard pair for my second system, now just to select the bass drivers.
As a starting point I will look at the Kappalite 3015LF as recommended, but I am open to options, including models from one of my favourite manufactures, Precision Devices.
changing driver
Hi there d: TH enclosures are quite sensitive to driver selection, assume you are simulating the above driver(s) for VT's fold, using HR. ...regards, Michael
The PD15BR40 or the PDN15BR40 look like a real possibility
Yes I will be looking vary carefully at this, including HR simulations as part of my evaluation.
Simon
