Amp Camp Amp - ACA
Am I understanding correctly that with the IRFP044 you are getting rising gain as the frequency increases, until it oscillates at 130K?
The freq response in the article with IRFP240 seems very well behaved
Hmm... I never went back to compare to the plots from the original article. Yes, I am getting what appears to be rising response with frequency with the 044 part. I'll have to run my signal generator directly into my scope to make sure it's not an artifact of an out-of-spec generator.
I never thought much of it, just attributed it to what people described as bright on top :confused:.
I'm still learning and I've re-read the ACA article multiple times, but my uneducated guess would be the gate stopper resistors (R5, R6), C1 at the output, but the rest I'm not sure about..
Am I on the right track?
Zachary,
You are getting close. Refer to the AMP CAMP 1B schematic.
Ask yourself this. What are the amplifying components in the signal path in this circuit? What is the function of the 2SK170? What is a buffer? What is the function of Q1? How is Q1 biased? What is the different between the modes of operation (common gain, common source and common gate)? Although this article is his explanation on how opamps work, he does it by explaining discrete components first so check it out: https://www.passdiy.com/project/amplifiers/diy-op-amps
How does the function of Q2 differ from Q1? What is a current source? What are the components of the current source in this mu follower type circuit? Why use a current source in the 1st place?
What is the feedback path of this circuit?
The answer to your queries: The main amplifying component in this circuit is Q1. The signal goes in the gate which is where R6 is, and out the drain which is where R1, R2, R3, R4 are connected and finally through C1 to eliminate DC, so that the "AC music signal" is sent to your speakers. From the input side, the AC signal goes through R11, C3, then the 2SK170 JFET buffer and onto R6.
Q2, and several other components surrounding it, are all part of the current source.
If I were upgrading parts for this circuit (and I am not recommending that you should, since that can be a rabbit hole from a $$$ standpoint!), they would be R11, R12, C3, R6, R9, R1-R4 and finally C1. R13 and the LED are useless to me, and I personally would not even install them.
Best,
Anand.
Zachary,
Best,
Anand.
Thank you, this is exactly what I'm looking for. I'll have some spare cash soon and figured why not upgrade a few ACA components, and try out a linear power supply.
Thanks again Anand
Actually 24v has been used by many people and there seem to be no problems, in fact they prefer it, so 22-24v would be an upgrade with no downside...
19v PSUs are so popular for laptops that they cost about half what 24v PSU's so that's the main reason Nelson spec'ced them.
I am new to building an amp and electronics. How do you learn about power supplies, in regards to changing the power source for the ACA from 19v to 24v?
Also, I know there are secondaries on power supplies that can provide power to another component, but not sure how to do read or do this. My questions stem from that idea of powering the aca and the aikido lv off the same transformer(s).
Enochrome,
I was wrong about the overall gain of the 6GM8 version of the Aikido LV line stage, by just a few dB (see our discussion on pages 326-327 of this thread for a refresher). The overall gain is about 15dB, I had thought that it was 17dB. To calculate the gain of any Aikido circuit it is always equal to 1/2*mu. The mu of the 6GM8 is 14. 1/2*14 = 7. A mu of 7 is equal to a gain of 16.9 dB, by using this equation: dB= 20* log (amplification ratio or gain ratio). Here it is 20*log(7) = 16.9dB. In real life though it is a little lower as shown in the link below. So the actual value is about 15dB.
The overall gain of the ACA is about 14 dB.
Total is about 14+15 = 29 dB. That would be close to the overall gain of the amplifier.
You can most likely use the same switcher supply that is supplying the ACA, since the Aikido LV draws such little current or you can design a separate linear supply for just the Aikido LV and run the ACA off the switcher. Your choice and free for experimentation.
Details on the actual gain of the 6GM8 Aikido LV, and examples of linear supplies for that design is right here.
Best,
Anand.
On the original pcb with 1A bias, I get this.
1W rms into 8 Ohms.
I'll retest it with bias mod.
