845/211 driver circuits
I think that if your speaker have over 88db for me the sound of the 211 is better and easy to drive and don´t need NFB,
211 bias -70v with a d3A, E280f or with 6e5p ( with preamp ) have a very good sound.
Source follower change the gentle sound of the tube for me.
My last 211 monoblock
Load with CCS or gyrator low Z, you will have a very good amp.
can you check dht tube in drive ?sound of dht 3d and balance .
Maybe something different like a grounded grid cathode drive.
H-S, that presents a load significantly below the plate resistance of the driver element( the triode connected audio beam tube ).
I am doing a PP cathode drive amp. It uses a 600R line driver output TX secondary to power the cathode circuit. The front end is two stage; an EL84 LTP driving Plate-to-grid FB'd TV sweeps, likely 6CB5A's. The finals are zero biased. With the zero bias, I take the bias circuit out of the equation; I don't want another power supply on the grids for when they go positive. The finals are HY51A's with B+ adjusted to set their idle current and attached to a 10k a-a OPT.
cheers,
Douglas
The usual B+ levels associated with 845's leave much latitude in driver/voltage amplification stage design...there are many volts to play with...:) if you want a triode driver, find a few type HY40. Think 3 6SN7's in parallel with a 40W plate and a Thoriated Tungsten cathode.
cheers,
Douglas
