100W Ultimate Fidelity Amplifier
Hello.Concerning active servo psu from earlier post i found some schematics on the web.In the lm317/337 variant i will replace the 2k2 resistors with 5K trimmers to have variable output.There are versions with the value of feedback resistor being 33K and others being 3.3K.Which one to use?
  • Negative feedback circuit using AD827 or OPA2604 or NE5532 based high bass tone circuits for sch.jpg
mr mile
planning for preamp psu
which is better of your design of the following regarding noise,impedance and stability in that order
1.A class preamp psu
2.PSU for preamps with Serial Regulator(http://www.diyaudio.com/forums/power-supplies/164365-class-preamp-psu-3.html#post2481652)
3.Simple Shunt PSU for Preamps(http://www.diyaudio.com/forums/power-supplies/164365-class-preamp-psu-5.html#post3466883)
4.active servo psu from above
thanks
Use active servo psu with LM317/337
PSU
Please check this layout, i attach psu with 7x15, LM317/337 with and witout trimpot to adjust output voltage. If ok, i'll provide pdf files.
do you do the layouts for apex?, they are almost same😀....BTW, nice layout.
in my opinion, its better to keep the trim pot.+ there are some requirements as per data sheet of LM. do read it.
do some reading on the forum,
class -A or shunt regs are better (in my reading) than chip regs. In this thread, read Jwilhelm's post for class-A.
Read Salas shunt reg thread for Mr. N. Pass's B1 buffer!
regs
Prasi
hi ,
please do not mistake me
i do not ask questions without putting some work into it.after reading most of work but understanding very little about them , and measured performance of various preamp supply on line forum , salas favoured by this , (https://cdn.head-fi.org/a/6482736.gif)
jung favoured by ostripper in this thread " Pitchfork pre-amplifier" incidentally lay out was by jwilhelm
when i saw opamp based design from mr mile just wanted to ask his opinion
may be mr mile can explain why he preferred active servo over A class ,is it due to simplicity or performance
i could not find performance of mr miles design , if u have u can point to it
thanks
