Building Visaton kit, advice needed re wood thickness
Hertzschmerz, thank you for the feedback on the Experience V20 - I had no idea the kit has been around for such a long time! I will adapt the plans slightly to allow for the 1mm difference.
I hope then that the Rotel amp with its excellent damping factor will do the job (I have faith in the amp that the THD will be ok at lower ohms), I think 100 watts will be suitable for most of my usual listening - I do plan to buy a PA amp with at least 500 watts for the rare occasion when I will be pushing the speakers louder.
I honestly can't see that a 1mm difference is cabinet thickness is much of a worry, but we like to get things right. 🙂
EXPERIENCE V 20
The project is downloadable as a .bpj projekte file:
https://boxsim-db.de/experience-v20/
That just goes in the projekte folder: Downloads
All looks good to me. It's actually a butterworth phase on the MTM section, which is very Joe D'Appolito, and gives good power response.
IMO, not so good (if Boxsim is reference)
If you are going to criticise something you should give a reason. Better still, fix the problem. Otherwise it's useless.
An exaggerated frequency response scale along with an overly detailed resoulution would probably make any speaker look awful. But I really don't see much wrong with this one. I couldn't improve it.
c.f. Troels Gravesen's Classic 3 way: SEAS-3-Way-Classic
590043d1483638947-help-first-crossover-design-3-way-eton-speakers-troels-3-way-classic.png
Aside from doubling and halving of crossover values to allow for doubled drivers, it's scarcely different. It's a good design.
The Visaton drivers are pressed chassis, but not unlikeable. The G 25 FFL - 8 Ohm is scarcely different from the H0881-06 27TFFC.
An MTM design always get criticised for lobing, but that to me is a feature. It has a PA like projection and goes loud. The impedance is commendably flat, the phase is nicely 90 degrees, and I don't think a big 100Wpc Rotel amp will struggle with it. A fine design IMO.
It's just a driver artifact on the W 130 S - 8 Ohm.
A FR peak at 1.3kHz. I had a better time modelling the 4" W100S-8, as it goes. But that won't go as loud. If you were going to hammer this speaker at parties, a 1A fuse on the tweeter circuit would make sense. Might protect the amplifier a bit in case the tweeter blows.
Thank you all for your input. I will certainly assess the midrange when these are up and running.
Steve, your posts give me confidence in this project. PA like projection and the ability to go loud is a feature of MTM design that appeals to me greatly. Most of my listening will be either solo or with the family, but I will also be using these speakers at parties, some louder than others. I will on occasion be hammering them yes, not often but it will definitely happen, and so I appreciate the advice of adding the 1A fuse.
