That was not a rant. I was saying what I think, not what I feel. Feelings are irrelevant to how cables work.stvnharr said:Dave,
Nice rant. Don't hold back. Tell us how you really feel.
You used the word "perplexing". Now you say that you didn't actually mean 'perplexing'. Difficult to make progress if you say something different from what you mean. 33 words in two sentences (post 50) hardly constitutes 'rambling on and on' unless the reader has a very short attention span. If I said "nothing" then how could you describe it as "perplexing"? Are you easily perplexed?You didn't say anything in your post that I called "perplexing". You just rambled on and on in your usual fashion about nothing.
The cable meme goes deep into peoples' feelings. They cannot imagine that a simple cable, as used by engineers, can be as good as a complex cable with carefully woven strands and a good story. They think that if many people spend a lot of money on cables than they can't all be crazy, and those nice people selling the expensive cables can't all be ignorant or greedy.
It is true that some RF coax may be insufficiently flexible for audio use, but some coax is more flexible than others. Try some of the thinner ones. Or even a simple lapped screen cable meant for audio. These are cheap and flexible, and in many cases are perfectly adequate. No need to tell your friends how little you paid.
Ok, so define 'better'. More flexible sure, but for signal integrity what do you recommend and why.
Well, better can mean a lot of different things to different people. I was thinking "better" in terms of more flexible and easier to work with, not signal integrity.
All I can say is that I have never run across any coax cable that was very flexible. Perhaps I've lived a closed life, I don't know.
When I started to make my own cables 15 years ago I started with braided magnet wire because it was cheap and it worked. This was at the time when the Jon Risch designs with Belden 82947, a coax cable, were all the rage. I just went a different way.
Now, I have enough cables for my needs, with plenty of extras.
Thanks for the reply.
This sounds to me like RG-6 or RG-59 cable, from the local hardware or electronics store, that is normally used in television antenna wires. Not long ago I used some to get better television reception when digital broadcasting came about.
I don't know why one would want to use it for an audio interconnect. Sure it will work if you get each end connected properly. But it's pretty minimum. It only has a single layer of braid which you have to use for the return. At least the Blue Jeans cable has a double braid so the outer one can be a proper shield.
The very first diyaudio project that I ever did was nearly 25 years ago and it was the construction of a proper shielded interconnect. It came in a kit with all parts included. The final product had a twisted pair for carrier and return with a couple insulation layber around the cable and then a copper shield over that. And it had nice Cardas rca connectors on the ends. I took a lot of care in construction and it came out well. I still have it somewhere but haven't seen it for a long time. I should try to find it and use it again.
Read what I actually said instead of making rubbish up eh!
Jean-Claude Van Damme or some imposter?
PBJ Kimbers were Good affordable cables.
Easily Diy'd if wanting a 10$ IC.
Erm Andrew the third wire is only connected at one end it acts as the shield Surprised (or Perhaps Not 😉 by your question.
Coax's as interconnects can be Problematic. But Hey! whatever blows yer Jets. It's just some Iffy music recording after all.
How can a wire connected at one end only act as a shield, a shield has to... SHIELD the wires! e.g. a co-ax. a single wire connected at one end usually ends up acting as an antenna.
dka for diy interconnect You find good information here ZenWave Audio
and You can contact Dave from Zenwave Audio,A very friendly enthusiast
Zenwave Audio
Is this real.....
Hehe, these are mystery men who know stuff you can not imagine, yet they have not heard of Van Damme cable, go figure
There are many different coax cable part/model numbers that fit the generic RG6 or RG59 Type numbers. Some are designed for high cable TV frequencies and some for low frequencies. Moral is don't select a cable based on RG Type numbers. Look for cables with heavy braided shields.
Such a freebie will be significantly worse than a decent coax due to poor shield coverage and highish shield resistance, yet it still works fine in most systems.
Many freebies I've dismantled revealed cynically minimal shielding and often clear signs of decomposition and corroded conductors. They're free for a reason.
That shows that you didn't have a hum or inteference problem, so a bad cable worked OK. Audio electronics is like that: it is quite forgiving of poor cables, so peculiar DIY (or expensive commercial equivalents) can often work reasonably well.stvnharr said:When I started to make my own cables 15 years ago I started with braided magnet wire because it was cheap and it worked.
Others may help me here, but the only genuine engineering application for a braided cable I can think of is a low inductance earth strap i.e. all the strands wired in parallel to make effectively a wide single conductor. This is the opposite of what you need for sending a signal and its return current.
Yes, freebies can be awful. Yet people still sometimes find that some freebies work better than expensive cables.
I can remember several times over the past few years on this forum when a newbie has been astonished to find that replacing his expensive (or DIY) audiophile interconnects with the freebie cable which came in the box with his CD player got rid of hum and interference so he could just listen to the music.
I plead the 5th here, but I can definitely say that ditching my Kimber Kable (both interconnects and speaker wire) made a huge difference in overall quality of the sound. I used compression connectors for the connection (Belden solid copper for the center conductor) and was very pleased with the sound and the reduced noise. I am not a big fan of Kimber as I noticed a severe amount of oxidation on the copper when stripping it and loss of detail over the years(I've had them 10+ years). Plus, I can build interconnects rapidly this way and at much reduced cost. I also provided a pair of my homebrew connectors to a family member and he was also very pleased by the results in his system.
What did I make up?
I think I've written a few times that the only coax I've found here where I live is the RG-6 and RG-59 coax. I've since read that there are other coax cables, so you must have been referring to those. Sorry but I was unaware of them. But since a couple posters mentioned vandamme cables and google is my friend, I have now learned about them.
As an example - Belden 1505A. Stiff? Yes, but once in place, I don't go moving my equipment around. Insert and forget, as far as interconnect goes.
I found some sellers have bulk rolls of this stuff and sell it cheaply by the foot on ebay.
@stvnharr: have you never taken a laptop apart and seen the wifi module with MMCX connectors and 1mm or smaller OD coax? If you google 'micro coax' you will seem some very thin and flexible stuff available for specialist applications, like schlepping LVDS between PCBs. There are hundreds of types of coax out there. I used to specify some that was made on the same sort of machine that bends wheelbarrow handles. Each for a use. 2.5 inch heliax off cuts are useful as a bludgeon for example 🙂
For single ended audio this is about as good as it gets Van Damme - Specifications - Pro Grade Classic XKE instrument cable and available in pimpy colours to boot.
Bill, I have never taken a laptop apart.
And thanks for the recommendation. I've had trouble getting one. Next time I look to make some cables I will look for it.
I have never had a hum or interference problem with a cable. Any cable that caused that would obviously be a bad cable.
My braided cables are not bad. It's just that you don't like them. You can cite numerous engineering based reasons why braided cables are not the best. But it doesn't really matter to me.
And as long as I've had music systems and listened to music I don't think I've ever heard differences in interconnect cables. And I've had everything from cheap to dear in cables. So I generally don't fuss too much about them.
I only responded in this thread because the OP had some spare wire and wanted some helpful opinions in making an interconnect from it.
Braided cables are bad, but in an electrically benign environment their badness is hidden so they can work OK. The big snag is that there are a lot of people out there who sincerely believe that braided cables are good i.e. better than other cables. The most helpful opinion for them is to tell them that they are mistaken.
Have you tested?Is this real.....
You will answer me that this is not necessary because.........Listen before writing your resentment😉
- Design & Build
- Construction Tips
- Diy kimber interconnect
