Polarity - external 12V AC power supply
I wanted a better 12 volt AC power supply to replace the wall wart I was using. I ordered an external 12 v AC PSU that looked from its photo to be well made..
The PSU consists of custom manufactured prefabricated parts. Everything inside plugs into a predesignated slot. Therefore, I can not switch any wiring internally at the IEC socket. My AC power is in reverse polarity to what the PSU was built for. I can not flip the three prong plug.. My AC outlets have been wired correctly.
Just so happens.. I had ordered it with two umbilical power cords, each having its barrel socket reversed from the other for different components it may power. I was able to correct the polarity at the component itself by using a reversed barrel connector. But, the PSU itself remains in reversed polarity.
By having corrected the polarity at the component itself, but not the PSU? Are the any negative effects from the reversed polarity remaining inside the PSU on the audio? Should the PSU be corrected at the source? Or, has any audible distortion been cancelled by what I did? .... Anyone?
Thanks... Gene
Sorry but that's.... i will not say what, you get the point 🙂
There is no polarity on AC power line, the only thing you need to make sure is proper earth connection, it is called AC after all, jeez, learn much physics at school?...
I am sorry that you do not understand how it applies to an audio component. I realize AC is alternating current. But, there is a phenomena that takes place that is audible when all your components line up with how the current is flowing into each unit. Maybe someone else some day will explain it to you. At this point it appears you know everything to know. So, I will not try.
Sorry... you might never know how good your system can sound ...
I never stated i know everything, but i know how to distinguish real physics from myths.
Read this as often as it is necessary to understand it: There is NO polarity on AC power lines!
Everyone here will tell you the same thing.
OK... We are thinking in different terms.
Just? Try the test shown in the link I gave with your VOM meter.
https://www.gcaudio.com/tips-tricks/determining-proper-ac-polarity/
You will see what I speak of for yourself. Then we'll talk.
There is something taking place in a component's chassis when the plug orientation is reversed between the hot and neutral. This will be consistent from one component to another. And its sounds better when the goal is reached for each component in your audio chain..
This may help too...
https://www.youtube.com/watch?v=p2u-URwIUgo
A mains transformer is likely to be slightly asymmetric with respect to stray capacitance from the primary to other nearby stuff. Hence reversing mains phase can sometimes bring about a minor change in hum or interference. Small effect, and probably inaudible in most cases. Which way round is best will be different from one item to another, so certainly no need to line them up or any such nonsense. Like all small, usually negligible, but real effects this has been blown out of proportion by some audiophiles. Others, who don't actually understand the effect, then regard it as important.
There is no such thing as polarity in ac. You are talking about phases and how they enter your equipment, right?
Like a 3 phase motor will change direction if two phases are switched?
That is how the term "polarity" is used for audio in the United States...and some other countries, too. For my polarity direction finder designed for audiophiles was made in Japan.. Directions written in Japanese.
Namiki direction finder
I guess the OP is talking about the type of power cable that only has neutral and live .
I remember reading Hi-Fi magazines years ago that advised trying this type of cable by inserting it one way then turning it over so the connector pins locate in the opposite side.
One will give a better ' flow of electrons ' apparently and better sound quality.
Snake oil for people with too much time on their hands.
edit i didn't read all the thread before posting , it's already been called ...... hiiisssssss 🙂
Its not snake oil. But? For you it is. I hope someday you learn what a transparent audio system can sound like and what it will reveal.
Its not just for two prong systems. You need to make a cord with the ground plug removed to test. Its a consistent phenomena. And, I do hear differences easily. I just removed the ground insert from a cheap cable and use that for testing purposes only. It works. It shows correct orientation.
Some manufacturers get it right. Some do not. I guess some feel like some here do. It makes no difference? Yes it does. You can hear it if your system is transparent enough.
