100W Ultimate Fidelity Amplifier
The two alternatives could make a big difference to the stability margins of the amplifier.
The 220r/180r changes the input LTP current. Increased current increases the open loop gain.
The 680r/2k2 changes the closed loop gain. Decreasing the closed loop gain increases the feedback ratio.
Moving both of these in the same direction could turn a stable amplifier into a oscillator, or a version that cannot reproduce fast signals properly.
I can't understand how these two changes came about without an explanation of their effect.
de
you need to put a footprint on switch base
yes ofcourse, here is the revised one. it seems I did make the previous layout in some hurry. as i put holes threre and not pads!😱
FA9
The first board is populated.
Here are the first measurements:
operating voltage +/- 18V
quiescent current: 17mA (typically Class A 😀)
offset 4mV,
measured voltage gain: 1
no distortion, nice sine, all transistors are (very) cold
regards Olaf
