100W Ultimate Fidelity Amplifier
I was intrigued by the active servo psu design in post #9450 for which prasi has done an excellent pcb layout. Its not immediately obvious to me exactly how it works, but looks to be a noise cancelling design where the opamp has unity dc gain and an ac gain of 30 - why 30? I'd be very grateful if you could enlighten me apexaudio. I see pcbs and kits using this design on ebay so I guess you're aware that your(?) design is widely copied in China.
This Thread must set a record for submission of the most proposals for untested amps ever.
Andrew thats simply not fair comment. Most are tested and most (almost all😀) are working.
dont you agree that they (posted designs) are different topology and gives one a chance to study and compare ? and most importantly, when tested by enthusiasts which is exciting for prolific builders like olafK, Terry, 44250, and many others? Find out the flaws, if any, with design and find the solution?
e.g. Just one example that I had the experience, there are many more in the thread with different people. its the FX-8 amp that has given good experience, the feedback ckt values were changed after Terry posted scope shots, which gave almost perfect square wave response on scope for bass frequencies.
Most would agree its all DIYA is about, people will feel they have contributed.
If one posted all tested designs, then it will become boring for some adventure seeking enthusiasts very quickly and it may even lead to finding some other past time.
My opinions/guesstimates only, based on reading of this thread!
AA9 low bias
Here is my AA9 ,it play without noise or any strange sounds. But i can not set bias higher than 500 mA and lower than 350 mA. Layout is from post #9421 (Prasi gerber file).
What can I do to fix this problem?
zoky2
