Pass XA25?
Still need to remove R21 and R22 since the manual states that there is no degeneration in any stage.
Hold on to your hat... I think the circuit configuration is different than what we previously thought....
As you just said, there are no de-generative feedback resistors.
With this information at hand, I think the circuit is something like this:
As you just said, there are no de-generative feedback.
The manual states that the amp is three stages, and the circuit you've just shown is only two. At least using the Pass Labs forum method of counting, where we don't count cascodes as a separate stage.
It is clearly seen that the DRAIN pins of the output devices are connected together...
This connection (the output node) is then fed back to the lower PCB...
The mounting holes on the MOSFETs have one round hole in a solid metal side and one routed hole through the metal. You can see the right-hand MOSFET has the routed hole on the right side. The gate and drain connections are on the same side as the routed hole, while the source connections are on the solid side with the round hole.
My apologies, but your explanation does not make things any more clear.
Could you please use the picture above?
What do you mean "the round hole in a solid metal side" as opposed to "one routed hole through the metal"?
Dear Alexiss:
One hole is actually a slit, and the other is a hole. The gate and drain are on the side of the slit, and the sources are on the side of the hole.
So the sources (left side of MOSFETs in the picture of the XA25) are connected together, and on the right sides of the MOSFETs are drain and gate.
The thing that is fooling us here is that both wires on the right side are red (respective blue), but you can see that one wire is thicker than the other - the thicker one is the drain, the thinner one the gate.
Unfortunately, I can't quite read the print on the PCB where Drain an Gate go to ... 🙂
Best regards,
Claas
P.S.: Seems like we crossposted a bit also 🙂
The red leads and blue leads are actually separate the sources are indeed the outputs. I had to check production the picture is confusing.
OK, now I got the confirmation that I needed. Thanx Mr Wayne.
Then the possible solution once again becomes:
As can be seen, the input resistors are given values, and the degenerative local feedback resistors are gone every where.
It would be interesting to see if this is correct or not..
