CLT-1 filters. This is a passive way to get to -160dB. As usual the circuit doesn't show how difficult it is to make passive components to do this.
To get >5% THD (so that simulator truncation, rounding, etc are negligible), I had to include a fairly large and not-weak nonlinearity.
Remember that a perfect triangle wave, when fed into a THD analyzer, records about 3% THD, and yet nobody would say "that's a moderately decent sinewave". Mine is a lot worse than that.
That's what you have in a state variable filter. It attenuates harmonics from upstream sources but not particularly from the opamp itself. It can exacerbate harmonics by demanding more current at a point in the waveform that where the crossover nonlinearities are highest.
Scott, Dick Burwen USED the 911 IC, he didn't design it. He would select out from a number of 911 IC's and put them in a HYBRID MODULE with a few surrounding passive that he sold to Mark Levinson.
The Harris 911 had a true PNP internal transistor. Check it out, this IC was made with an alternate process, that is WHY it was so expensive at the time. It was made from radiation sensitive environments. Please check things out first. The HA911 was a pretty darn good part, sometimes. It also often suffered from Xover distortion, but if you selected them out, they were reasonably OK.
in this case post #1462, #1463 and #1467 under
http://www.diyaudio.com/forums/everything-else/169484-what-wrong-op-amps-147.html
is also of interest.
yes. pooped. its quick conceptual.....scott. use appropriate topology. and it IS the topology I am/was asking about. yesterday, I did throw an opamp onto breadboard --- signal to inverting input.... gain less than 1.
However, Any specific suggestions? Need steeper slope, too.
-Richard
The point is you can never get below g=1 noise gain from the feedback loop. At all frequencies. Therefore, any harmonic removal of the now-added opamp must come from a downstream passive filter. (The newly added opamp/filter CAN knock down upstream harmonics generated from prior stages, obviously)
Air core L's and the best C's keep the L's several feet away from metal with any magnetic hysteresis. Putting a diagonal cutter next to one of mine caused odds at the -145dB level.
You are asking for essentially what is impossible any active filter will have it's own distortion appear at the output depending on the noise gain at that frequency. You do realize DPH's use of the term noise gain had nothing to do with noise?
Attached is a picture of the CLT-1 low pass filter. You can see the three coils inside their aluminium cans. I believe there are ferrite pot cores inside. The USB stick is for scale. This filter is tuned to remove the third harmonic of a very clean 10 KHz sine wave with up to 1W passing through. For a 1 KHz filter I guess the coils will be 10X the size?
In the CLT-1 manual they say a lead pencil tip next to a lead wire can cause harmonics.
