F5 power amplifier
That's not what Builders find.
I agree,Andrew, loosing my rare JFET & my less experience is the problem....found a way out...used a less powerful power supply with 4A rectifier to limit current to stabilize the bias around .40V on output resistors..then gradually moved to higher current PS, finally the actual PS that could provide ample juice...and was able bias it around .60V (about 1.2A in A class) for testing, now will build second channel similar fashion and bias full when I get that into a chassis
Sent from my iPhone using Tapatalk Pro
Biasing up the amp
Celebrating getting the amp together, thanks for all the help, cheers.
One channel working absolutely fine, second channel giving troubles...replaced JFET's, MOSFET's, trimmers ....but story remain's the same...Bias on output resistors tend to sync, but differ mostly by about .10V, and DC offset never turns 0, even after hours of playing....Surprisingly if I use lamp current limiter setup, the amp biases properly around 0.47V on both resistors, including DC offset to 0...
