HLCM - Horn loaded compact monitor
How do you like the D405Ti vs the M200? Always thinking under 2.5kHz. It looks interesting on paper, and I see it was measured in the JBL specs with Selenium HL4750-SLF horn, which is relatively small at under 20" width, and seems OK for crossing at 500Hz.
One is wider bandwith. I like the Selenium 400-7k. The M200 500-3k.
What seems isn't always so/ the narrow radiation selenium large format horn should be good to 500 with this driver. long deep horns is where it's at for the midrange
http://www.jblpro.com/www/products/selenium/hm3950-slf#.WOBbF6K1uwU
The JBL 2386 is better.
HM3950-SLF
Maybe 2386 is the way to go. They don't seem to keep directivity constant, though.
Too bad there is no 2" version of the 2384.
TWO DELICATE THUNDER TWEETERS COMPARED
HERE IS THE CELESTION CDX 1730 VERSUS THE CDX1425 MEASURED IN THE FAITAL ELLIPTICAL TRACTRIX HORN 60 DEGREE - NO EQ THREE FEET - 1/48 SMOOTHING
1730 1425.jpg😛
typically compression driver treble needs a bit of eq. this is the 1730 celestion with a series cap and resistor
the 1425 needs this type of eq
this too much eq for the 1730 to sound "right" BTW - i also screwed up and used the log scale
these are one inch drivers
FaitalPRO | HF Horns | LTH102
the 1730 is in the system, my bass and mid horn is more efficient than the 1425 especially after padding down the low treble. i tend to like a non metallic treble driver too.
Doh! The 102 is what I was thinking of, heh.
I hadn't noticed the diaphragm material difference, that's interesting.
I may need to get a pair to test as possible hf drivers in my synergys... price is pretty darn good.
hello, i cross it in at 85 hz, i was was using the fane studio 10m - the 10m has wider bandwith but where i am using the 8pe21 it has a sweet spot with less overall coloration
Hello Pooh.
I modeled in Hornresp the 8PE21 in a conical dual expansion, 22x22" mouth, 34" long, 3.5x3.5" throat, similar to Inlow's horn. I also modeled the 12PE32, used also by Inlow, on the same horn. Below is the comparative chart.
Grey is 8PE21, black is 12PE32. Going from this, where would you cross these over? It looks to me the 8PE21 would be around 130Hz (Inlow at 135Hz), and the 12PE32 at 115Hz (Inlow at 100Hz).
I would love to xo at 85Hz, but seems this is not the horn for that.
Hello Pooh.
Build the biggest horn you can live with, place it in your room and than determine where you will crossover. One thing that is missing with this comparison is the sound quality of the 8 versus the 12 in the upper range. I'd bet $$$$ they aren't even close. Those both look to be around 150 hz crossover but that would really need to be looked at in the room.
Understood. What are the dimensions of the horn you use to cross the 8PE21 at 85Hz?
