Tube Operational Amplifier
Do anybody experimented or work around Operational Amplifiers made only with vacuum tubes/valves (No ss at all)?
I have some ideas, but mu brain is open to newer/different ones. What I need is a differential triode/pentode pair wit inverting and noninverting inputs, one or two inverted outputs.
Any suggestion or example is welcomed.
The op-amp was developed and sold in 1952 by George Philbrick. It was tube based. Used for a number of years, mainly in analog computers.
paul
Thanks, Paul. I read something about it, but my doubt are the neon lamps in the signal path. Aren't they noisier?
I want to make 3 units to extrapolate an invention of a guy I know into the tube technology, he did it using SS and works pretty fine. By the moment, I reserve the basic idea of the thing.
My current idea is as follows: a (not exactly) differential pair made with a triode and a pentode inside the 8BU11 compactron tube. The last triode as a follower for the output. This tube with filaments grounded at 0VDC. A 6U8 tube, with the pentode as CCS for the pair, an the triode as CCS for the output triode. A neon lamp to give biasing for both CCS, with heaters near the negative rail (I called it Ekk).
The project resembles this, but it is not equal to the showed below. It uses different array of passive elements. Nor it is of the Bubba topology.
Sorry, I still have no permission to give more details, because it is under development and perhaps it will be patented. It has been designed in the Campus of an University in Argentina and I am not the creator. Only a second test of the principle.
Code:
Operational amplifiers was invented for and used to to perform matematical operations like integration or derivation in analog computers, in those applications noise was an issue but not as important as in low level audio amplifiers.
I think there is one on Nelson Pass "passdiy" site. Go to "projects" and hit "amplifiers" then on the Project categories list on the left hand side a number of articles will emerge. About a third of the way down. It is called "DIY op amps"
It is a 2 tube simple opamp. 12 AX7 I think.
Cheers
Jonathan
