Hypex NCore NC500 build
The real limitation is not being able to bypass the buffer. You can always add a buffer of any grade if there's no buffer or option to bypass the on-board buffer. It would be nice to see all of the all in 1 integrated amps (PS and amp on 1 board) with a header pin buffer bypass jumper.
When I asked Hypex if there was a way to bypass the buffer on the MP series, they said "no, you don't need to because the opamps and regulators are of the highest standard already"
I guess that means they think the NE5532 is better than the discrete buffer in the Mola Mola Kaluga 🙂
The new HSR discrete regulators look pretty fancy though. Wish I could give this thing a listen.
Transformers are always somewhat problematic in terms of linearity and bandwidth. Do you have any measurements?
Dynamic range is better than 120dB. As long as you don't feed them any DC, they measure great. The way they increase current and lower output impedance as they attenuate, seems to be the biggest advantage. I've yet to hear anything close. Which is why I'm willing to spend several times more compared to the next best option for them.
Rough layout of my big custom Purepower 🙂
Not sure I see the advantage - don't you need the lower output impedance at higher signal levels?
Rather than ******* the current away as heat, they increase current and lower output impedance as you attenuate. If anything more current and lower output impedance is more desirable at lower levels. However at unity gain our gain stage has a 10 ohm output impedance, and can sink/source 60mA running in pure class A, while meeting the specs on the Weiss OP2-BP datasheet.
http://www.weiss.ch/files/downloads/op1-bp/OP1-BP-Datasheet-R1.pdf
Why would that matter? We are talking fractions of milliwatts here, and you "burn the current" (no, you don't - you dissipate power) in all the resistors and transistors in your circuit anyway.
That as what I was questioning. Why is more current desirable at lower levels?
Nice, but what has that got to do with the autotransformer?
The reason it's more desirable is because you can take all of the noisy active gear out of the path, and not lose anything as you attenuate. All other passives sound thin as you lower the volume. They can even provide up to 7dB gain as well if needed.
Best thing to do is listen to them. People don't spend $2000 on volume control parts alone, just because they suck. And it's not "euphoric coloration's" that make them good. It's the extreme transparency.
And you can get them wound with 6N silver but that adds $2500 for a balanced set! There's 500ft of magnet wire in each one. Then multiply by 4 for a balanced set. They need 32AWG magnet wire. 6N silver magnet wire in 32AWG, costs over $1 per ft if you buy it massive quantities.
Even a normal resistive attenuator doesn't attenuate at all at full volume, and even your autotransformer attenuates at lower volume settings - that is what a volume adjustment does.
And why is that? Can you explain what is causing that effect?
All nice, but you didn't actually answer my questions. 🙂
So, why is more current desirable at lower levels? And what has "However at unity gain our gain stage has a 10 ohm output impedance, and can sink/source 60mA running in pure class A, while meeting the specs on the Weiss OP2-BP datasheet" to do with the autotransformers?
I try not to wrap my head around the technicalities too much. These are proven units with 1000's of them out in the field already. I've listened to every type of attenuator on the planet. Nothing has sounded better to my ears than these unit's. And I'm not alone.
Better guy to talk to is Dave Slagle if you want all the fine details. He has a great forum as well. Massive resource of information on there:
:: Index
I've kind of noticed that. 🙂
So those autotransformers are great because <technical mumbo jumbo that sounds good>, and they are Really Expensive. Fair enough.
Listen to my Puregain gain stage equipped with the Weiss OP2-BP's, followed by a balanced set of slagleformers', then quality headphones driven direct, and you won't need to ask any questions anymore. Everything that matters will be answered within seconds 🙂
