There are currently two versions of the Hermes isolator. One for the Amanero USB module, and over for the Beagle Bone Black (Hermes BBB). They are both designed to connect to Cronus for reclocking. Botic is a software audio driver for Linux on the BBB.
Read the beginning of this thread for more information. Also, read more about the Botic driver here.
Ok, I get it, its in your TP website, sorry, I never noticed. Anyway, the cronos is out of stock, but the hermes for BBB is not. So the correct question I guess is when are you going to have the Cronus again?
Alex
Alex
I have new boards on hand now. I need to build/test them, so they should be available early/mid next week.
Hermes-BBB-Cronus
Ok, thanks brian, I will go ahead and order them as soon as they are available.
Alex
Alex
They are available for pre-order now.
BBB cape showing OOS for a bit. Available again soon?
BK
Hello Russ / Brian,
is there any timeline "Hermes-BBB Isolator Module - Out of stock" will be available again?
Hans
Hans
Is it possible to pre-order the out-of-stock Hermes-BBB Isolator Module with Cronus and Cronus Re-clocking Module with 45.1584/49.152MHz Rhea Pair, or should one just wait till it is back in stock?
I have two i2s sources for one i2s input in my active preamp.
I want to :
1. switch between my 2 sources
2. isolate
3. re-clocking
I imagine this setup:
[I2S from Digi+ Pro (Raspberry PI3)] + [I2S from Amanero] ===> [OTTO-II 2:1 Mux] ---> [Hermes-xxx?] ---> [Cronus Reclocker] ---> Najda DSP (24 bits, 48/96/192 kHz)
Is it right ?
What Hermes module should i use ?
Hermes-BBB have got i2s input and 2:1 Mux ?
What Rhea module for 24 bits, 48/96/192 kHz ?
PS: I have already an OTTO-II 2:1 Mux
Henri
I want to :
2. isolate
3. re-clocking
Is it right ?
Henri
I just ordered more boards - so we will have them in the next couple of weeks. 🙂
Cheers!
Russ
Hey Russ, any updates on the Hermes boards? I've been keeping my eyes peeled on the site!
Sorry - had to abort that order because of a board redesign (not the Hermes BBB) - I just made a special order with just those boards. 🙂
Thanks! No problem at all. I'm finishing up my DAC project in the next month or two so I want to make sure I get everything squared away on the source side.
I have been a TPA customer from nearly their beginning. The world of DIY has changed over the years. Now, relentless unauthorized copying by foreign vendors using inferior quality materials is practically rampant. It is diluting the best creative efforts of generous, dedicated designers (not only at TPA) - enthusiasts who serve a small clientele and take satisfaction from others' execution and enjoyment of the quality designs they have created. Thus, I no longer expect the kinds of full design disclosure that was formerly common. If it sounds good, it IS good.
Best,
Frank
Sent from my iPad using Tapatalk HD
Best,
Frank
Hi Russ,
After received the Cronus-Hermes-BBB since 2015, I finally going to start on this but found that the thread had been really grown. Sorry for having so many questions.
I want to have BBB rev B -> Hermes-BBB -> Cronus ->I2S -> Soekris R2R DAM1021
For Hermes-BBB
1. Is Hermes-BB power by BBB? Do I need power connect to the 5V_IN ?
2. What about BAT? Do I need to connect this?
3. What about the EXT_BAT ? What is this use for?
4. Is J1 require shorting?
5. Usage of J_RST, J_P_SW, J_RE, J_ADC ?
Cronos (RHEA 45.1584/49.152)
6. J1:1, J1:4, J1:2 - Which one to use? And when to use DISABLE?
7. Do I need separate power supply (5V) connect to VD?
8. Should I just need 33R for R5,R6,R7?
9. Where can I find the datasheet for Cronus or Hermes ?
Software
10. What else do I need to run Squeezelite other than Botic ?
11. Does Volumio works on Botic ?
Thanks for the help, I know I may be a bit late to start it now.
For Hermes-BBB
Software
Hi all!
Since I have a problem with my BBB/Hermes/Cronos/B3 (running in stereo) configuration,
I now try to get some help here.
Before I had a B3 with Legato output stage, and everything worked as expected. So the jumpers on the B3 are installed, like described in the B3 manual.
Then I added the BBB with Hermes and Cronos, and when I do a speaker test in a terminal (speaker-test -c 2 ), then both channels are playing every time, instead just the left OR right.
When I check the 8 channels (speaker-test -c8), than just channels 0 (Front left) and 4 (center) are playing, all the remaining 6 channels not. I think, that in stereo configuration there should be the test signal hearable from all channels.
So it seems to me to be a problem with the routing.
And as I checked, there is the possibility to do some routing on the B3 itself at the bottom with jumpers (mine, as mentioned, are configured like in the B3 manual),
or with the resistors at the Cronos (R1-R7), and also in the software, as you can see with alsamixer in a terminal.
I installed only jumpers R5-R7, and also checked their resistance, and they are fine (measured 33 Ohms).
Now, I played arround a lot, but I don't find a hint here at the Twisted Pear's forums, or any manual or tutorial, (which is still missing).
I hope somebody has a tipp for me how to get the thing running as expected!
Many thanks
Matthias
Yes it is important if you are shorting signals the B3 to omit the resistors that are not actually driving the net. So for typical stereo B3 usage - only install the resistors R5 - R7 on the Cronus. Then use the jumpers on the B3 to enable stereo remapped usage.
Many thanks
Matthias
Correct. Botic/BBB can render 8 channels of PCM, but it seems you want only basic 2-channel stereo into the B3, correct? Have you configured ALSA in Botic for more than two channels? That could result in the behavior you describe. ALSA mixer should not be needed. Plus, "speaker-test -c 8" will not help diagnose routing errors if Cronus output is enabled for only one I2S stream. The default configuration of Botic should play stereo correctly. If these basic hints don't help, perhaps move the question to the Botic support thread.
Hi Francolargo,
thanks for your response!
I discussed it already with Miero, and so I think this is not a software problem. (But of cause I could also be wrong.)
I didn't touch the alsa config.
But how I understand it, if one tests all 8 channels in a stereo configuration, all of them should be part of either the right or the left channel, otherwise the power in the DACs output wouldn't add up to 8ma (I just put the 8 there from memory.)
Francolargo, do you have a hint where I further get information on the alsa thing?
This all comes back to a missing description on how to set-up this all correctly and how all this interacts. It's all just scattered over several threads. 🙁 Sorry to have to say this.
Perhaps someone from Twisted Pear could chime in, just to check if this is hardware related (if I have to re-arrange some jumpers on the B3, or change the resistors on the Cronos?
Ahh:
I hope my English is good enough that I didn't insult someone or that my write-up seems to be rude. This is not what I'm intending, just describing the situation and asking for help. I enjoy diy, and also my DAC, and therefore am happy that all twisted pear gear is arround!
Ahh:
- More Vendors...
- Twisted Pear
- Hermes-BBB/Botic cape for BeagleBone Black
