here is the layout that will be produced.
For vcc or gnd or vcc- connection, it is possible to use 5.08mm pitch termi blocks or faston.
for led resistor, upto 12.7mm pitch spacing is made.
4-leg reservoir caps can be fitted as designed by Project16
the specs will be
160mm x 100mm, 2.4mm thick FR-4, 70um copper, double side, green solder mask on both sides, white silkscreen, HASL with lead /tin. lead time to receive is 15-20 days.
I have calculated the per pcb cost, it is 4.75USD+paypal charges+shipping charges.
once i receive pcb, i will pm for address and payment.
regards
Prasi
the specs will be
regards
Prasi
Hi Prasi,
I'm removing my request and going to the Quebec Diy GB.
So i've removed my request. Thanks.
nounouchet (4 boards)
haddock (2 or 4 boards)
mcandmar (4 boards) ok
Project16 (2 boards) ok
muhy3 (6 boards)
Myint67 (6 board ) ok
gwrskien (10 boards) ok
asuslover (2 boards)ok
ssarchy08 (4 boards)
Morde (2 boards) ok
Ryssen (2 boards) ok
bristto (4 boards) ok
pjr3s (4 boards)
joshvi (6 boards)
Marra (4 boards) ok
patriz (4 boards) ok
gnomcat (10 boards) ok
bloozestringer (4 boards) ok
bOTL (10 boards) ok
Prasi (4 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
rephil (10 boards)ok
muhy3 (6 boards)
Morde (2 boards) ok
pjr3s (4 boards)
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (4 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
Hi Pinnocchio,@kokanee
@ppap64
Please pm me qty and full address. I will fulfill you two but I'm not adding anymore to the list as I was already not planning to do this big and want to avoid customs paperwork for this GB. I was not trying to discriminate anyone, I just don't have much time these days, that's all.
Do
could you do me a favor and remove those names thats already on your Quebec list? this will give me a fair idea on number of spare boards...some people are late to change their GB requirements to Quebec as they might be busy.
thanks and regards
prasi
Pinnocchio, Prasi,
If I order the 10 boards thru either of you, are they the same boards as in Post#101.
Also Pinnocchio, what is the cost for the 10 pcb's and shipping charges to Calgary, Alberta.
Once I have the information, I will PM the person I will be dealing with.
Thanks,
Myles
Thanks,
Myles
Hello everyone
Just a reminder regarding PCBs at Jim's Audio, 24 PCB still available!
For those who would like to have boards and who will not be in this 120 pieces buying group it is still possible to take them at Jim's Audio using two-pin snap in capacitors and adhering to the caution.
Regard's
Regard's
Did visit the quebec diy and found pjr3s and Haddock are already on that list, so deleting their names. Wonder why they didnt update the list themselves...adding JJGB to the list.
muhy3 (6 boards)
Morde (2 boards) ok
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (4 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
8 boards remain..
muhy3 (6 boards)
Morde (2 boards) ok
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (4 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
8 boards remain..
I will get 2 more, if it's ok .
muhy3 (6 boards)
asuslover (4 boards)ok
Morde (2 boards) ok
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (4 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
6 boards remain..
muhy3 (6 boards)
Morde (2 boards) ok
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (4 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
6 boards remain..
Its fine asuslover, thank you for posting.
To all, PCB's ordered. The supplier has kindly agreed to first produce a pilot batch of 10 PCB's. I will test a PCB and give a go ahead for production of 120 PCB. Yes, I will have a total of 130 PCB's (including 1 test PCB). This activity will add another 18 days for getting the 120 PCB's in my hand, but will ensure assurance of tested PCB's.
So here is the revised list
muhy3 (6 boards)
Morde (2 boards) ok
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
16 boards remain..
reg
Prasi
edit: I intend to remove those names that have not said ok for the revised GB by tomorrow evening, so as to free up for those in waiting list+ not end up with additional PCB's. I have to know the final list, so as to quantify the final order for manufacturer. I hope everyone understands this because of economics.
muhy3 (6 boards)
Morde (2 boards) ok
joshvi (6 boards)
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
16 boards remain..
reg
Prasi
So here is the revised list (removing those names that haven't reconfirmed)
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
36 boards remain..
reg
Prasi
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
36 boards remain..
reg
Prasi
Hello prasiTo all, PCB's ordered. The supplier has kindly agreed to first produce a pilot batch of 10 PCB's. I will test a PCB and give a go ahead for production of 120 PCB. Yes, I will have a total of 130 PCB's (including 1 test PCB). This activity will add another 18 days for getting the 120 PCB's in my hand, but will ensure assurance of tested PCB's.
It's a wise decision!
I think there will be no problem and have discussed it on the other forum and with all the checks done.
I still want to thank you for taking over this buying group because it is not easy and with the size and the imperatives of these PCB the sums of money committed are consequent.
Good luck prasi
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
joshvi (4 boards) ok
32 boards remain..
reg
Prasi
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
32 boards remain..
reg
Prasi
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
zrxshack (4 boards) ok
28 boards remain..
reg
Prasi[/QUOTE]
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
28 boards remain..
reg
Prasi[/QUOTE]
Hi Prasi
I have added my order below and updated the "number of boards remaining".
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
mituisho (4 boards) ok
24 boards remain..
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
24 boards remain..
Hi Prasi
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
outtek (4 boards) ok
20 boards remaining
Regards.
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
20 boards remaining
Regards.
Hi Prasi
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
Pepperman (4 boards) ok
16 boards remaining
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
16 boards remaining
Hi Prasi
Do you know shipping costs to France ?
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
Nounouchet (4 boards) ok
12 boards remaining
Thanks!
Morde (2 boards) ok
Marra (4 boards) ok
bOTL (10 boards) ok
Prasi (3 boards) ok
emynet (2 boards)ok
TIC37 (4 boards)ok
Sadik (2 boards)ok
JJGB (6 boards) ok
12 boards remaining
- Group Buys
- CRC Power Supply (Class A amplifier)
