I suppose I should have said "hearing impaired".
[emoji106]
Verzonden vanaf mijn iPhone met Tapatalk
[emoji106]
Unfortunately it seems your emoji 106 is a non-standard one.
Hi, I'm new to Daphile. I've installed it on a small Intel Atom fanless PC
https://www.aliexpress.com/store/pr...32580905881.html?spm=2114.12010608.0.0.aUXPaP
Using it with SMSL M8.
Works beautifully apart from a couple of small things. Hope someone can put me on the right track...
1. The little PC has an SD card slot but if I put a card (formatted NTFS) in it isn't recognised???
2. Can only use DSD over PCM. In "Native" mode I can hear faint music and a lot of static. Have played around with the settings but nothing works.
3. Can't get any version of Shairtunes to work. Sometimes I can see it queued up and playing on Daphile but no sound is heard. Has anyone got Shairtunes working on Daphile? Is there something else that needs to be installed (WaveIn??)?
Thanks guys 🙂
Thanks guys 🙂
Have you tried the SDcard formatted as Fat32 ? 🙂Hi, I'm new to Daphile. I've installed it on a small Intel Atom fanless PC
Thanks guys 🙂
Yes. Same! Nothing shows up under "Settings, Storage". My external 500GB drive is there but that's all. Tried a few different CD and Micro SD cards but none show up.
Hopefully, this might be useful to other Daphile users:
My little PC's built-in wifi wasn't recognised so I bought this...
https://www.aliexpress.com/item/Hot...32659894879.html?spm=2114.13010608.0.0.bZrjPp
Dirt cheap but is working well!
Great to see Daphile on the waiting list at Distrowatch.....
http://distrowatch.com/dwres.php?resource=links#new
Show your support and speed it along by clicking on 'recommend' there 🙂 (It is about 2/3rds of the way down the page.)
Friendly bump. 🙂 Well done !, you have moved Daphile from 1 vote to 23 !... The nearer to the top it gets the sooner it is on the Distro list..😀
(note to self..must stop clicking 'recommend' every time I go to Distrowatch...😱... seems all of my 6 clicks have counted....😀...
You didn't hear it here....😉😉..)
Some people are not able to hear subtile differences. Blindfolded or not
Unlikely, though I can see expectation bias clearly.
Yet another candidate.
Most of Chinese DAC's are without native DSD support, whatever they say.. they using old sw for XMOS, without licence..Using it with SMSL M8..
..only use DSD over PCM..
Use DoP, there is no sound difference..
XMOS chips work with native DSD on Linux without licence. There is a sound difference if you have good hearing. Although the packing and unpacking of DoP is lossless and bit perfect, the unpacking process causes a significant load on the XMOS chip inside the DAC. This load creates more noise inside the chip that get's transferred into the clocking and data path. It's not huge, but there's some. And it depends on how resolving the system is to really notice subjectively.
I'm not saying that..Provide some objective evidence that galvanic isolation is a fraud then.
I claim that sellers a can't be part of objective discussion, especially when subject of topic is directly related in part of electronics where their products belongs..
That is not hard to understand..
Not true.. I'm not talking about drivers, there is not only one sw version for XMOS.. Native DSD in Linux works only with newer..XMOS chips work with native DSD on Linux without licence..
Anything U8 or newer is fine. That is now almost 4 years old now.
Again, this is nothing more than cheap advertising for items which you sell..There is a sound difference if you have good hearing. Although the packing and unpacking of DoP is lossless and bit perfect, the unpacking process causes a significant load on the XMOS chip inside the DAC. This load creates more noise inside the chip that get's transferred into the clocking and data path. It's not huge, but there's some. And it depends on how resolving the system is to really notice subjectively.
There is no sound difference between DoP and Native DSD..
By the way, your claims about hearing could be easily described as discrimination, or something worse..
So you think I'll sell more by telling people to use 1 free mode over another? I make the same money whether people use native or DoP with our DAC. I didn't mean to burst your bubble, I'm sorry but hearing ability is a prerequisite to be able to hear. This is an audio forum. You listen to audio via the sense of hearing
SMSL M8 is older than that?Anything U8 or newer is fine. That is now almost 4 years old now.
This is DIY Audio Forum..This is an audio forum..
Many people tried to make speakers or amplifier only with their ears, and that was disaster.. but with microphone, multimeter, and maybe some knowledge one can make very decent.. without listening..
If you want to make good products people enjoy listening to both are required.
I asked you about SMSL M8.. do you have some idea why it is without Native DSD support..
- PC Based
- Daphile - Audiophile Music Server & Player OS
