Valve Itch phono
Which one, the 820k one?
Upper tube V4 is biased with cathode resistor R11 and grid (leak) resistor R12 right? Normal auto bias uses R11 to lift the cathode over grid reference in that most or all current passes thru the cathode and not the grid (hopefully).
So what I want to try and understand is why you set R12 to 5K6 2w. Is it carrying a current?
