how long is your amp been operational?? please share your schematic with the modified inverter
Thanks stewin. I do not have the schematic. I do routing with eagle manually. This is a habit . Inverter is like aud600 with 74hc00 instead of 74hc04. It is 2 months that I test it 4 hours work with high power with 4 ohm resistive load without problem. But irfp250n needs a big heatsink and it stay cool. With small heatsink temperature. Increases rapidly + 70 °. I use aluminum 1cm thick / 6cm / 10cm for 2 irfp250n and its cool
have you ever tried to remove the resistive 4ohm load when the amp is operational at high spl??
zobel is 10r + 100n. and i put 1k ohm 2w output load resistor. reponce is yedwith no issue. and high frequency + 20 khz must be filtred in input preamplifier. no smoke at all test
D
Deleted member 148505
If you're experiencing problems when speaker is disconnected at high volume. Try to put antiparallel diodes (>= 4 amps rated, ultrafast) after the output filter. The amp module also needs very good overcurrent protection circuit. So that when speaker is removed while playing loud, the amp will survive.
Or you can put a dummy 150 ohms (30W) load that is permanently connected to the output.
Use dummy load with lowest resistance that will make the amp stable, but high enough such that when amp is driven at full volume without speakers attached, the dummy load will dissipate low heat as possible.
thanks lester
mr stewin. without load when i increase volume ocp is activate ! it is high current problem when lc filter resonnate? anti parallel diode is it a sollution? i see them a standart rectifier diode at output with iraudamp 7 schematic
If you're experiencing problems when speaker is disconnected at high volume.......................... So that when speaker is removed while playing loud, the amp will survive.
Nonsense
If you make a normal , stable feedback in your amp - nothing of that kind may happen .🙄
my friends. I did the same tests with qsc pl 380 at a friend. I disconnected the speaker and I increased the gain and the amp goes into protection mode. Lpf resonnance is normal and it is necessary to provide good protection
A good amplifier doesn't switch off when the speaker is disconnected.
pafi sorry i can't hear you. seriously !!!!!!!!!!!!!!!!
Even test with 2 amp xls2500 and xls1500 and without charge it goes into thermal protection
Those are not good amplifiers then. Resonance is not neccessary. It's a harmful side-effect, and it should be avoided. Try ucD!
More than 10 years ago I designed a ClassD amp with resonating unloaded filter. The manufacturer/distributor refused it.
D
Zobel network with right values also lowers the Q factor of output LPF. It will make the amp stable.
Also it is better to put lowpass filter to the input of the amp, with cutoff frequency that is lower than the resonant frequency of the LPF.
erro no d900
Good morning, Merry Christmas to all, with the irfp4768 can use 120 + 120 volts, in the scheme of the D900 hybrid, it would not be wrong to connect the base of q1, because it should have an LC network to oscillate. And happy new year to all Can publish the archie in ltspice
I have something faster if you like.
I make this as I am not happy with the output of two legs of resistor under LTP 😀
ltspice file is attached in the PDF also.
Jlester,
These compromized solutions help somewhat at the price of higher loss, lower transmittion bandwidth, but the correct solution is much better.
You can set high resonant freq, but it will increase loss and output ripple. You can set input bandwidth limit, but it is a loss in quality, and still doesn't solve the problem, only eases. A good UcD amp can have significantly higher bandwidh than its output filter, and no resonance can be observed with any practical load.
In case of UcD a zobel network is also beneficial, but not the way as in a pre-filter fed back amp. In case of UcD switching freq is affected somewhat by load impedance, especially at very high modulation index, and this dependance is lower with zobel. But no resonance at the filter freq.
why ? all self oscilate class d have this problem. and many class ab also!! congratulation pafi for your hard work
By the way , the UcD is more unstable vs the prefilter feedback amps. They need carefully adjusted feedback .The amps based on IR2092 configuration have no such issues in ALL conditions !!!A good UcD amp can ....
I believe that there is a mistake in Q4 of this scheme because I think that the base should not be linked to the gnd, someone can give a help because it is not able to make it work ..
This problem? What do you mean? Resonance of output filter without load? This is independent from the oscillation method. This depends on feedback topology (pre- or post-filter).
And why is this unacceptable? Because it activates protection as you saw. And this can happen not only at completely disconnected speaker, but also with a woofer with low pass filter (very high impedance at high freq). Also because zobel can burn out by a sustained resonance.
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
