Yet another CCS
Just another, cheap parts...
So here is another thought with regards to current source vs gyrator - are there other parameters that are different besides the PSRR?
First picture is a current source, and the second is a gyrator using the same FET (MMTD1N50T).
There is a noticeable difference in harmonics, IMD, and the noise floor between the two.
How do these effect the perceived performance of the amp?
Besides the PSRR, I should add self generated noise.
Other parameters such as impedance are directly related.
Please forgive my ignorance, but I am still thinking about measuring harmonic distortion on a device that attenuates, say 100 dB, the 1 KHz fundamental.
I assume that your graphics are from the complete stage (CCS/Gyrator) + Valve, otherwise -10 dB @ 1 KHz is a very poor performance.
BTW, I did a Google search for MMTD1N50T and nothing happens.
The 1KHz is the test signal, it is not suppressed. This was a test of a complete amplifier for harmonic distortion.
That explains all, my fault, sorry. I meant that does not make any sense to measure harmonic distortion on a circuit that has a very high attenuation.
Thinking of a typo, I did some search without first and last character, but Google works not so great on this side of the world, maybe connectivity also help to that, last night Internet connection was intermitent.
why you do not use P transistors? You should get better results, at least avoiding of bias currents flow into signal lines. (if your goal is max impedance)
i) Uncertainty principle: When I find a good idea I do not find good mathematical models, and when I find the models I am too dumb to have a good idea. 😛😀
ii) HV P-MOSFETs do not abound, following Rod Coleman's advice I tried the FQP3P50 with poor results.
I have no formal education in electronics, but seems to me that modern MOSFETs has tons of transconductance and low capacitances are a weak advantage, so the last cascode is a natural approach, my only doubt is the useness of C1.
But hey, results are great, just compare with DN2540 cascode
http://www.diyaudio.com/forums/tubes-valves/299317-yet-another-ccs-4.html#post4898417
