Please help repair JVC A-X2
Hi!
I purchased JVC A-X2 amp in mint condition.
After a few hours of listening the fuse has burnt. The amp was dusted inside and had original parts, I am sure it was not repaired/modified before.
I checked inside, and right OP transistors were burnt. I mounted A1943/C5200 instead but in both channels this time. After powering up I checked the voltage at OP trans bases, it was OK, I set the bias and let it warmed. After 15 minutes I connected the speakers and heard good quality sound of music. Until the first louder drum kick… then the amp smoked right channel OP and drivers trans this time. The left channel remained OK.
The picture from ltspice shows real measured voltages and some calculated currents.
The problems is, that I have +34.6V DC at the bases of the drivers.
I checked all of the parts on the pcb with the probe and it seems that the transistors were OK.
It looks like the current through Q4 is too small.
When measuring the voltages at the basis of Q1, Q2 and Q6 after connecting DVM it slowly lowered what was a bit strange because of high input impedance of DVM...
After some time those fluctuations were visible at right channel amp’s power indicator (-40 dB blinking) what was another mystery without OP transistors mounted…
Do you know what part is suspicious looking at the schematic?
Thank you in advance for any suggestions.
Check the fuseable resistors, they are designed to fail under stress. This amplifier is designed to drive 8R speakers NOT 4R!
See page 1 of the service manual under 'specifications'.
Dear!
Thank you for helping,
OK, I burned the amp with (maybe) wrong load, please help to investigate which parts might be broken.
Partial incomplete LTSpice circuit was only to show actual measured voltages.
Spot on, Eagle Aye😉...But as I have suggested in the previous versions with a single transistor constant current sink/source for the upper and lower branch of variable bias circuit will work as intended. In your version (which is probably more accurate than mine), you effectively replaced one transistor for CFP-Compound Feedback Pair (aka Sziklai pair). May I suggest to put another resistor (value from 1k2-3k9) from Q17 collector/Q18 base junction to Q7 collector in order to avoid possible oscillation in CFP...do the same for upper and lower branch.🙂
Hi!
I think that JVC made (non)intended mistake with this Q4 type on the information sent by you.
