What is wrong with op-amps?
Where can you buy lt1358 chip? Internally it is very different than what I normally use.
Superceded?
Digikey. PM me and I will send you some that are just slightly over my noise spec.
Robert was indeed kind enough to send me some specimens to try out, needless to say I am excited because these have a different topology than what I normally use.
Since the whole system is a symbiotic relationship I was thinking of setting up a test in a different manor than discussed in this thread. I want to make a circuit with 10x gain for different opamps, say 4558 and the LT1358. I will have a partner swap out the black boxes and see if I can hear a difference once levels are matched. What I want to do different is use a microphone and REW to make total system synergy measurements. I can also do some regular distortion measurements too but most likely the distortion will be below what I can measure:bulb::spin:
Ultra Analog used to be a maker of DACs in the late 80's/early 90's. It was a USA company. So now I see a UK operation selling a surface mount chip mounted on an 8 pin dip socket adapter board. Nice, I guess, to commandeer a respected name and sell part soldering services at a hefty markup.
Same address as the company.🙄 Let's see, what is the minimum investment for an new IC op-amp? And the plan is to sell them one at a time on eBay? Am I curious enough to buy one and have it de-capped?
Or we could just compare the specifications with existing or recently obsolete products. Probably less than 20 we would need to search. But then they might be selecting chips and dumping the rest.
But the humor is that the magic opamp is a monolithic unit!
Those tubular resistors are/were common in tuner modules, ditto tubular capacitors.....what's special about them ?.
Dan.
I was thinking selected LME49990. It didn't come in a DIP. Of course no longer available. They did restart production on many of the previously discontinued parts. But not those.
Makes sense, but as I explained to a QC guy years ago noise does not have a normal distribution. If typ really is .9nV there are 0% well before .7nV. They also take a hit for no reason on specing 20% or so more slew rate (unless the spec is sandbagged OR they are making it up).
4558 with biased outputs using 7K5 resistors to + rail are different beasts compared to unbiased opamps. Try and compare. If it did not work I would replace all opamps in my console to something modern.
Using just a resistor to sink current from an op amp output forces it to drive not only DC current to do the biasing but also AC current has to drive the load. An active device mostly just sinks DC and is a very easy, high impedance AC load on it. Compound that bias resistor with the not so robust output drive ability of the 4558, well its no wonder the high frequency envelope of the vocals of Wave's outdoor setup were strained.
I'm still going to try it (4558 +7.5k pull up) once I can get a little setup made to buffer the 4558 from driving the 600 ohm RIAA network I use. I'll see, but I don't think it's going to be pretty.
