The food thread
Goose is also traditionnal around here for Christmas (Liège at least). The traditionnal recipe is called "oie à l'instar de Visé" and is a bit more involved than just roasting the beast.
You first cook the goose whole (removing first as much fat as possible) in a vegetable and chicken stock. When cooked, you cut the bird in pieces (one piece per person). For all the small bits falling apart, you "stick" those together with fat to make a bigger one (these are the best in the end...). Best done the day before.
The day you serve, you roll those pieces in eggs' yolks and dried breadcrumbs. Brown first in a pan with oil. Dump the oil and add a bit of butter and goose fat, cook a tad more before serving.
To be served with pan roasted potatoes (good ones, such as the ones below) and a white sauce made with a roux based on goose fat, in which you mix tons of garlic.
Those potatoes (or a type very, very similar) are called Pink Fir Apple in the UK.
They are best flavoured spuds I've tried and they keep extremely well, 8 months is no problem and after all that time they still taste like you dug them up yesterday.
Yield isn't great and peeling them would be a pain.
There is another strain with the same shape but purple flesh. Look nice if you sauté them mixed with yellow ones.
If you like duck you owe yourself a goose!
The trick to get the skin crispy is to pierce it all over with a fork (just the skin mind!) and pour boiling water over it a few times then let it dry in the fridge overnight.
Make sure to catch all the fat that drips out while roasting and a goose has two inner compartments which can be stuffed individually.
Definitely lo-fi meal -- meatloaf with a combo of beef, lamb and veal. We cheat a bit on the cardiological imperative of low sodium so use pre-fab bread crumbs a la Pepperidge Farm stuffing. For 1.5 pounds of meat, a beaten egg, breadcrumbs, 1/4 cup HOISIN sauce and a good squeeze of ketchup. Roast until the temperature has reached about 155F.
