does the 3A5 have the stones to drive a 2A3?
Hi Jaap, yes, you could certainly try it, though whether you need it very much will depend on the type of output valve.
But with all closed-loop systems, please take care to see that frequency compensation is correctly applied.
I imagine that you are using a high-performance, wide-bandwidth transformer - it will be needed!
Place the compensation cap in parallel with the output resistor. Take care that ferrite-beads are present on all the susceptible nodes (anode, PNP base & collector), and that they are lower-frequency types - losses in the 500kHz-10MHz range are needed for these.
screen the feedback wire, and keep all of the circuit small.
After ten years absense while doing other fun activities not involving electronics, I stumbled upon this thread and had to give it a go. This concept seems to work OK in the simmed world with parallelled 3A5 as driver, Had to spend half an evening brushing up LTSpice commandos.
Reactions: Bassling
Hi Andy,
Just a small try to see if I still had some knowledge left. Went through the neglected electronic workshop, to sort out things as we a have bought a new house and found this stereo 6B4G PP chassis with wired cathode circuits and a handfull of 3A5´s, but without drivers. Next sim will be a PP version.
Thanks pl802!
Hadn´t given safety a thought😛.
Can absolutely be built, but I would go for 6B4G with its lower heater current. Probaly needs some tweaking.
Senstivity is on the low side with just over 2V for 2W out.
Anyway, I pulled the 3A5 and got 105mA, 101V, 10,3W over the output tube, so it should cope. Also shorted the driver anode to ground and got 36mA, 350V, 12,5W.
https://shop.ehx.com/catalog/tubes-specs/6b4g-sovtek.pdf
https://soderquist.se/3A52A3choke.asc
Reactions: pl802
