The Best DAC is no DAC
Finally I can use my Amanero noDAC at 256 native.
I have compiled realtime kernel for audiolinux with official patch (LE) for Amanero and new firmware 1099c
Both Dop and native 256 very good!
Native 512 distorted.
We are almost there...
As a side note, my noDAC with only passive filter and Amanero is a lot better than the other with latest XMOS from DYIHNK
Which version of Amanero firmware are you using? Is it 1099rc1 or is it some other one?
I would appreciate some advice concerning selection of an inductor as I am not really sure of precisely what I'm looking for. I'm putting together a second order LCR filter as I am interested to see how it performs against my previous RC LP filter. The filter will be for a single-ended DSD project.
The filter calculator says I need a 5.6mH inductor. Would this be a suitable inductor for this project;
http://www.mouser.co.uk/ProductDetail/Sumida/RCR875DNP-562K/?qs=LKl/VGYbYti9huM1kr9AcQ==
or perhaps this if I use smd parts;
http://www.mouser.co.uk/ProductDeta...GAEpiMZZMsg%2by3WlYCkU2oPBW0WnPwqsDeCDbleA0Q=
if not, can someone point me towards what I need.
Thanks in advance.
Ray
Thanks in advance.
Ray
Hey guys nobody can help us?
TIA
Felipe
I have made some quick measurements of my two noDAC, using Audacity software spectrum analyzer and my Scarlett mic/line preamp. I have used a 1 kHz PCM tone at 44100 Hz, converted to DSD with HQPlayer (minringFIR, DSD7 noise shaping)
1) Amanero with the latest firmware 1099be and single RC filter R=33 ohm and C=0.1u
2) DIYHNK 768K with xmos xCORE-200 and 2nd order RC filter R=3300 ohm C=1n with output capacitor in series 2.2u
As you can see, in Amanero armonic distorsion is following a linear decreasing very similar to the distorsion beahavior of some SET tube amplifier.
In the second case there are higher order harmonics and noise is a worse. A "rrrr..." or, if you want, a "zzzz..." is clearly audible.
