Pass XA25?
I saw one at a picture from BAF2016....with hockeypucks. 700W 40 A 😀
Nice!
with IXYS IXFN ?
Two transistors beacause CCS maybe ?
Always interesting amp non surprise....oh yes 🙄
The only problem is, this seems to suggest a different front end,
"The simple front end circuit uses uses two pairs of NOS complementary in common-source mode"
Yep, I accounted for that. Used complementary JFETs in front end with IXYS mu-follower on output. Got results which were pretty close to the published specs. Power output matched into 2, 4, 8-ohms, distortion at 25W into 8-ohm was similar, but max power distortion into 2, 4-ohms was higher in my simulation.
